Prelude 97-01 stock rim specs? Tire upgrade information?
Old Mar 25, 2004 | 06:37 PM
danmanh22's Avatar
Default Prelude 97-01 stock rim specs? Tire upgrade information?
Does anyone have specs on stock Prelude 97-01 rims? All I have been able to find is that they weigh 19lbs without tire, and they're 16's.
Specifically, I am trying to find the rim width because I want to upgrade tires. I currently have stock Bridgestone Potenza RE92's 205/50R16, and I want to slap on a set of Falken Azenis 215/45ZR16.
I have been told by several people that they should fit fine, but the Falken website says that the approved rim width for this tire is 7.0-8.0 inches, and I am not sure if my stock rims are that wide.
Any and all information would be appreciated. Thanks
Old Mar 25, 2004 | 07:07 PM
BlckBeautyVTEC's Avatar
Default Re: Prelude 97-01 stock rim specs? Tire upgrade information? (danmanh22)
i read you can out up to 10mm bigger on tire size so if that is so then yea thos 215's would be alright
Old Mar 25, 2004 | 07:15 PM
Soda Popinski's Avatar
Default Re: Prelude 97-01 stock rim specs? Tire upgrade information? (BlckBeautyVTEC)
We'll i think 215s would be too wide for stock rims, you should just go for the 205/45/16s. Azenis tend to be wider then they advertise.
Old Mar 28, 2004 | 05:19 AM
danmanh22's Avatar
does anyone else have an opinion of or pro advice for this? bump btw
Old Mar 28, 2004 | 07:52 AM
577HondaPrelude's Avatar
stock rim witdh is 6.5 inch.
Old Mar 28, 2004 | 11:20 AM
IhAvEaLuDe's Avatar
i just ordered falken azenis' for my 97 lude rims. 215/45/16's.. they should be perfect but i will let u know tommorrow.
Old Jan 8, 2005 | 02:32 AM
UA6 BALLER STATUS's Avatar
Default Re: (IhAvEaLuDe)
how wide is the Type SH wheel? 16x7???
Old Jan 8, 2005 | 05:54 AM
KENLUDE97's Avatar
Default Re: (Type SH)
The stock rim IS 6.5" wide. 215 Azines will fit fine. If you got were able to convince your tire mounter you might be able to a 225 on the stockers. i will be ordering a set of the 215 for Auto-x season.
Now the Azines Rt 215's wear out REALLY fast. If you drive them everyday you will need a new set... 6-10 months. But the grip is un touchable for anyother street tire.
Old Jan 8, 2005 | 07:51 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (KENLUDE97)
I ran 215/40/18x7.5 on my 00 SH.
Rims were Volk LE37T w/ 48+ offset.
It all depends on the wheel offset and your drop. There are people running 7.5 to 8.0 in wheel width.
I had no rubbing issues with mines with turning, only when I hit dips/potholes on the highway, the inner top wheel rubs with the top of the tire.
Remember, the wider the better. 7.5/8 + 225 will be great for handling.
Old Jan 8, 2005 | 09:15 AM
bad-monkey's Avatar
215/45/16 azenis will fit fine on the stock rim.
flashmang
Aug 22, 2005 07:11 PM
Loveless
Sep 7, 2003 08:14 AM
munscher
May 30, 2003 02:30 PM
illusion
Apr 29, 2002 06:46 PM
Jordan_4WS
Oct 18, 2001 12:09 PM
