help with tuning VAFC
Old Mar 25, 2004 | 05:57 PM
str8drift's Avatar
Default help with tuning VAFC
aight guys..here's my set up
i have a 95 gsr with
itr cams
jun chipped ecu
intake
header
exhuast with no cat(just str8 pipe)2.50
msd ignition
advance timing(which was like that when i bought it and i'm going to bring it back alittle closer to tdc)
vafc
aem cam gears
excedy stage II clutch
clutchmasters lightened flywheel
i just installed my N1 catback yesterday, and when i gun the car....it hesistates and startes popping like crazy...i haven't pushed it even passed 7g's yet, cuz it lags so hard.
I don't have an air/fuel gauge installed yet. so i can't tell if i'm running lean or not.
but anyways,
what setting could help this situation alittle until i go to a dyno?
what can i set my cam gears to also?
i pulled off my o2 sensor and the plug was white..what does that mean?
if anyone can help.
also when i input all the settings i have to inialize it then take it for a run? or how do i set it properly? thanks guys please don't flame i'm new at this, but i want to learn
Old Mar 25, 2004 | 06:17 PM
mmuller's Avatar
Mad Scientist
Default Re: help with tuning VAFC (str8drift)
what is your timing set at?
Old Mar 26, 2004 | 05:52 PM
str8drift's Avatar
Default Re: help with tuning VAFC (mmuller)
its prolly set at18, but i put it back to 16 degrees...but it's still making a poppoing noise.
Old Mar 26, 2004 | 08:48 PM
ReV LiMiT's Avatar
try changing your o2 sensor and see if that helps. if its white, that means the engine is running lean.
Old Mar 27, 2004 | 09:31 AM
str8drift's Avatar
Default Re: help with tuning VAFC (93sir)
ok..i'll do that when i get some more money...i didn't know that they were that expensive
Integgin
Mar 7, 2005 05:40 AM
ninjastance_batmang
17
Nov 8, 2004 12:59 PM
Eclpze97
Jun 14, 2004 02:10 PM
SPOONDB8
Jan 31, 2004 10:09 AM
PhuckinHondas
Nov 29, 2002 04:50 PM
