********ATTENTION Del Sol dohc VTEC owners and swapped Del Sol owners.....need help with swap.....mo
i will be installing my LS into my new Del Sol within the next two days and <U>i was told that the rear mount bracket on the DOHC VTEC sol is different than an integra rear mount bracket</U>.
i need varification before i try to do this swap and realize that i need to order a part
please let me know
thank you very very much
Modified by dirtyd463 at 9:43 PM 3/25/2004
Modified by dirtyd463 at 9:44 PM 3/25/2004
please let me know
It should be the same as 94 Integra bracket. You will for sure need a Del Sol dohc Shift linkage (NOT INTEGRA). I have the shift linkage that you need for 120 plus shipping.
actually the rear bracket is different
i found out the hard way today, luckily i had one not far from where i was at to get
the rear section of the bracket is about 1/2" longer
also i already knew about the linkage and i already have some
CopperSol
11
Dec 23, 2005 04:56 AM
hotimportcrx
Oct 23, 2005 03:37 PM
Sliced Beard
Mar 26, 2004 02:36 AM
