CEL: Swapped ecu's and it went away. BAD IDEA?
Old Mar 25, 2004 | 04:09 PM
sfjdmlud3's Avatar
Default CEL: Swapped ecu's and it went away. BAD IDEA?
I have a jdm h22a with a p13 4ws ecu. When i swapped the motor everythign was fine. about 2 months later the CEL went on and I didnt bother checking the code. I just asked my friend to borrow his Chipped mugen ECU (testing it out) and the CEL went away. Is this a bad idea? The car ran fine even with the CEL so I was guessing something with the 4ws? AM i hurting my engine in anyway? . Let me know thanks guys.
Another question if you guys know. When i replaced my radiator my mechanic said while he was filling her up with the motor on, said that my head gasket was going bad. He said he knew because when he was pouring in the coolant it was boiling and bubbles were coming up from the rad. cap but eventually went away. I DIdnt think anything was wrong, just air and heat since the car was running. My question is that can you actually tell that your gasket is going bad from just doing that? Or is my mechanic on crack? thanks
Modified by sfjdmlud3 at 3:28 AM 3/26/2004
Old Mar 25, 2004 | 04:22 PM
PrecisionH23a's Avatar
Default Re: CEL: Swapped ecu's and it went away. BAD IDEA? (sfjdmlud3)
The CEL is most likely something emissions related, I would check the CEL light though. It takes 5 minutes to pull a code:
http://www.hondaprelude.to/art....html
Your mechanic is correct about the headgasket. A good way to tell if a hg has gone bad is to run the motor with the radiator cap off. If tiny bubbles come up, that is a very good indication that the hg is slowly going bad. I would have your mechanic do a cylinder leakdown test on the motor as well as a compression test. Keep in mind, the cylinder leakdown test is more accurate then a compression test... but both of which can sometimes be misleading.
Old Mar 25, 2004 | 04:53 PM
AndyD's Avatar
The 4WS H22 ECU is the same as the 2WS ECU. The 4WS is not monitored by the main ECU. 4WS has it's own ECU in the trunk.
That should not be causing your CEL.
Old Mar 26, 2004 | 09:29 AM
sfjdmlud3's Avatar
thanks for that website preciscion. But wondering where that service connector thing is in a fourth gen prelude? HOw would i check the code for a fourth gen etc. thanks
kyang03
Mar 6, 2014 07:31 PM
Dannienguyen123
Dec 23, 2012 02:46 AM
psudo-si
12
Oct 29, 2009 06:56 AM
jneely
Feb 29, 2008 08:53 PM
DumpedSi
Aug 20, 2003 03:40 PM
