SIR Cluster connectors
Old Mar 25, 2004 | 02:50 PM
shawn_crx's Avatar
Default SIR Cluster connectors
Anybody know where I could buy the Connectors plugs for the SIR cluster?
Modified by shawn_crx at 12:51 PM 4/7/2004
Old Apr 7, 2004 | 09:52 AM
shawn_crx's Avatar
Default Re: SIR Cluster connectors (shawn_crx)
anybody?
Old Apr 15, 2004 | 06:46 PM
Davep's Avatar
You can modify the USDM plugs to work... The middle plug is a stock 4g 8 pin plug, fits fine. The plug on the right side is the stock 4g 12 pin plug that the outside wire on each side has been shaved off to fit in the slot. The plug on the left is the same 8 pin plug that is in the middle except the outside pin on each side have been cut out. So you will need to get a extra 8 pin cluster plug from the junkyard.
Here is the modified 12 pin plug
This will not get the green plug for the little 'car' that shows if the doors/hatch is ajar working but it's better than nothing.
And if you're wondering the two milky white connectors are from an '88 and the gray one is a '91 style plug.
jdmjin
Sep 26, 2012 07:44 PM
ef92b
23
May 20, 2009 11:49 AM
Punker1234
Jul 10, 2005 12:50 PM
Scean
Apr 1, 2004 09:14 PM
