went to the track with my del SLOW
i went to the wednesday night drag at Infineon Raceway yesthurday. and my times are :
1st run
temp ------74
humidity---58
R/T---------.156 .
60 ft--------2.415
330 ft-------6.7
1/8---------10.762
MPH--------56.22
1000-------14.515
1/4---------17.642
MPH--------72.74
2nd run
temp-------73
humidity---60
R/T---------.728
60 ft--------2.368
330 ft------6.736
1/8---------10.350
MPH--------67.97
1000-------13.424
1/4---------16.059
MPH--------85.16
3rd run
temp----- 68
humidity--77
R/T--------(-.253)
60 ft-------2.553
330 ft------6.882
1/8---------10.494
MPH--------68.09
1000-------13.565
1/4---------16.206
MPH--------84.68
4th run
temp--------65
humidity----98
R/T----------.173
60 ft---------2.590
330 ft--------6.909
1/8-----------10.908
MPH----------58.10
1000---------10.571
1/4-----------18.027
MPH----------61.02
i was running 27 psi on azenis with gsr swirlie/blade. my car is a 95 del sol VTEC. full interior, no spare tire, ground control coilover , kyb agx, oil level is half a quart overfilled, and 1/4 tank of gas. i was nervous and very tired (since i was studying for a exam the whole night before). i think my car is a VERY slow since d series hatch are faster than my b16 del sol. what do you guys think? is there anything wrong with my tranny cause it was hard to get into 3rd gear on all the runs, my tranny has no grind. i couldnt get into 3rd on my 1st and 4th run so i just went to 4th. and is too much engine oil bad?
Modified by sting94112 at 10:22 PM 3/25/2004
1st run
temp ------74
humidity---58
R/T---------.156 .
60 ft--------2.415
330 ft-------6.7
1/8---------10.762
MPH--------56.22
1000-------14.515
1/4---------17.642
MPH--------72.74
2nd run
temp-------73
humidity---60
R/T---------.728
60 ft--------2.368
330 ft------6.736
1/8---------10.350
MPH--------67.97
1000-------13.424
1/4---------16.059
MPH--------85.16
3rd run
temp----- 68
humidity--77
R/T--------(-.253)
60 ft-------2.553
330 ft------6.882
1/8---------10.494
MPH--------68.09
1000-------13.565
1/4---------16.206
MPH--------84.68
4th run
temp--------65
humidity----98
R/T----------.173
60 ft---------2.590
330 ft--------6.909
MPH----------58.10
1000---------10.571
MPH----------61.02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrfirefox »</TD></TR><TR><TD CLASS="quote">I think you just need to practice launching and drag racing.
My SOHC coupe runs faster than that.
Practice makes perfect</TD></TR></TABLE>
A coupe isn't a Del Sol though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">
Not too shabby. What elevation are you running at?
</TD></TR></TABLE>i dont know the exact elevation, but alot of people say the elevation at Infineon raceway is fck up because at the end of it, there is mild uphill.
when i should shift? before redline or 100 or 200 rpm over the redline?
Damn dude. Those are pretty shitty times for a del Sol VTEC. Are you sure the valve cover just doesnt say VTEC and its a D16Z6 or D16Y8? Dont blame the car by calling it a del SLOW. A person does have to drive the car for times... My del Sol S ran a 15.9 with just intake, and skunk2 catback. So something is definitley wrong with your car or you. Not trying to dog you or nothing.
Good luck with the problem.
Modified by JSPECHB at 6:19 PM 3/25/2004
i'm pretty sure it is a b16, since it does say b16a3 on the block and i do rev my car to 8000 everyday. i also saw another del sol vtec hit 16.1 and a 99 coupe si hit 16 something, 99 prelude sh hit 15.7, my friend's 94 integra gsr hit a 15.4 with just intake. i'm kinda disappointed with my times. i think it is my driving since i was really tired and nervous, but somehow not since other b16 cars were in the 16's too. so i am going to again in about a month with i/h/e and change my tranny fluid with gm syncromesh fm, and hx wheels.
you should be able to pull 2.2 60's easily on those tires. i pull 2.1's and have even hit 2.0's on azenis's with open diff. that will get you into the 15s most likely
i just saw you trapped 95! is that right? thats good for mid-low 14's!
i ran 17.2 with my d15b7 (93 del sol s)... it just doesnt sounds right to me... but eh what do i know
this was with just a short ram intake and that's it..
Modified by amy del sol at 8:27 PM 3/25/2004
Modified by amy del sol at 1:12 PM 3/26/2004
Last year at Nopi Drag Wars @ Gateway International St. Louis Mo. I ran my Del Sol So (D16z6) with a I/H/E. with 195/60/14 Azenis.
R/T .504
60' 2.482
330' 6.701
1/8 10.256
MPH 68.82
1000' 13.349
1/4 15.943
MPH 86.88
Just my .02
R/T .504
60' 2.482
330' 6.701
1/8 10.256
MPH 68.82
1000' 13.349
1/4 15.943
MPH 86.88
Just my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">2.3 is not horrible.
I think that 16.0 is about average for a Del Sol VTEC.</TD></TR></TABLE>
15.2-15.5 is avarage for a good driver in a del sol Vtec.
I ran a 16.001 at lebenon valley in a stock 93 si model. and lebenon its a known slow track.
The del sol vtec is rated @ 15.7 from the factory. A few basic bolt-ons and a good driver should be able to net 15.2-15.5. From my experience with my car, a good lunch is extremely key for the del sol to get it going and get a good time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GERM »</TD></TR><TR><TD CLASS="quote">am i the only one seeing that he is trapping at 95mph in his sig? or is that a mistake. cuz 95 and a 16.0 is horrible!</TD></TR></TABLE> your not the only one. it was a typo. i changed it like back to 85.
I ran a 16.6 in my basicly stock sol when i had my d16z6. For mods, all i had was TEIN HA's, 15inch rota's with pontenza so3's, Intake, and 2.25inch exhaust, and I am a pretty bad drag racer (I like autox much more). I thought that was pretty slow.
I would change the fluid in your tranny if you can't put your car in gear.
