TIAL Wastegate and 4-Bolt flange Dimensioned Drawings for you!
Here ya go guys. i made these in autocad, so email or pm me with you email if you want the files themselves. The pictures are 1:1 so you can print them out and they should be the exact size you need.
Hope these help
Hope these help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">What a sad attempt to impress us with your below average autocad skillz.
lol!
my acad skillz arent that great i know. but they are quite simple designs, so it wasnt hard. i can make you some solidmodels if you want
i just did these, cause they are what i needed to make for my car. i had my friend make a 5-bolt for my last turbo and he said is was a PITA!! trying to find the dimesions on it were crazy, they ended up using putty and stuff to get it right.
lol!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">Does the 2.500 mean 2.5 inches?</TD></TR></TABLE>
Yes. Using that many zeros means your tolerance is in the thousandths of an inch. Don't know if you meant to do that or not, but that can make things more expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke »</TD></TR><TR><TD CLASS="quote">ha. yea everything is in inches. i just left the decimal places out to .0000</TD></TR></TABLE>
Yeah my teacher flipped a **** when I did that on an assignment.
i dont have a avatar either but you guys are lucky im on jackass level i feel left out
posting pics of girls in the garage isnt that bad is it. lol
Do you have the dimensions of the actual 40mm Wastegate? need for a project thanks.
posting pics of girls in the garage isnt that bad is it. lolDo you have the dimensions of the actual 40mm Wastegate? need for a project thanks.
I'm assuming you measured the external values of the valves with a micrometer?
Or did you just get the dimensions from Tial?
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke »</TD></TR><TR><TD CLASS="quote">1 in = 25.4 mm so 2 inches = 50.8 mm
hth</TD></TR></TABLE>
ok I was wrong. But the Tial 40mm wastegate itself has a 2" diameter inlet.(which is what I measured the first time and just assumed that it was equal to 40mm) The wastegate flange has a 40mm inlet which is not 2.5" like you have posted in the pics. 40mm = 1.57480 inches not 2.5"
the 4 bolt is for the turbine exit which is 2.5 inches. i just used calipers to measure this stuff so its prolly not accurate down to .00000000001. the second one is for the tial 35-38mm/deltagate style wg. i hope this clears up the confusion.
oh and some ppl imed me saying that they wanted these, but i forgot and never sent them, if you want them please email me at burkemdavis2@yahoo.com
later
later
i want to know how big the WG is like 5inch tall 3 inch wide ect.
i need the maximum dimentions
thanks
thanks
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke »</TD></TR><TR><TD CLASS="quote">the 4 bolt is for the turbine exit which is 2.5 inches. i just used calipers to measure this stuff so its prolly not accurate down to .00000000001. the second one is for the tial 35-38mm/deltagate style wg. i hope this clears up the confusion.
later</TD></TR></TABLE>
lol. i just finally got it. I thought for the whole time that 4-bolt = 40mm tial wastegate. wow, sorry about all that.
Same...Since you started the thread with "Tial wastegate..." I think we just assumed that was the 38mm and 40mm flanges.
</TD></TR></TABLE>Same...Since you started the thread with "Tial wastegate..." I think we just assumed that was the 38mm and 40mm flanges.
Never heard of using PCD's?
Whats the distance between the holes in the x-direction or do we assume there the same as the y distance?
