Problem with abs, power mirror, and A/C lighting
Old Oct 22, 2001 | 08:02 PM
SHystrdyGSRtdy's Avatar
Default Problem with abs, power mirror, and A/C lighting
Hello,
Does anyone know if the ABS harness, or anything that has to do with either the ABS, power mirror, or A/C lighting is next to the o2 sensor by the cat?
Old Oct 22, 2001 | 08:47 PM
Turbolude's Avatar
Default Re: Problem with abs, power mirror, and A/C lighting (iLUVmySH)
they have nothing to do with your o2 sensor wires. You prolly just blew a fuse.
Old Oct 22, 2001 | 08:49 PM
ShowSpeed's Avatar
you guys knw if there's a fuse for the rear reverse light? (i checked the bulb.. and it was ok..)
thanks
Old Oct 23, 2001 | 05:44 PM
Default Re: Problem with abs, power mirror, and A/C lighting (Turbolude)
If anyone has a Helms manual please help me out. I have a volt meter hooked up to the red and black wire of the a/f meter.
I have the a/f meter tapped into the yellow&brown , black w/ silver dots, and solid white wires of the ECU.
I have a tach tapped into the yellow&green wire in the ecu. Power running from #5 in the fuse panel by dead pedal, and grounded near hood popper.
At first, I tapped into the wrong things. My a/f meter, I tapped into the thing behind the dist. next to the valve cover. (Has a short spark plug wire running to it) Does anyone know what that was?
Then, I tapped into the black&yellow wire in the ecu. Does anyone know what that wire is?
I redid all of the connections, so now all my meters work but now my abs light is on, my a/c doesn't work, and my power mirrors don't work. I know it has something to do with the install. Maybe it was one of the harnesses next to the o2 sensor. There were two harnesses that converged, one was o2, I don't know what the other was. But both were reconnected properly. Please help!!
[Modified by iLUVmySH, 2:45 AM 10/24/2001]
Old Oct 23, 2001 | 07:23 PM
prelude1897's Avatar
Default Re: Problem with abs, power mirror, and A/C lighting (ShowSpeed)
there should be a fuse for your reverse lights. It either in ther motor or by your foot.
mint95gsr
Sep 23, 2013 06:15 AM
JustinHoMi
Jan 11, 2012 06:52 PM
justdoinme23
Aug 25, 2010 04:37 PM
trrbl1bmx
Mar 7, 2010 02:40 PM
MyWhiteCivic
Sep 24, 2002 06:01 PM
