JDM H22 O2 Sensor Wiring?
Old Mar 25, 2004 | 11:13 AM
Ri5e's Avatar
Default JDM H22 O2 Sensor Wiring?
The JDM H22 Harness:
Yellow/Black
Green/White
Orange/White
Solid White
And the O2 Sensor:
Two Black
White
Green
I did a search and I could not find out which one to connect to?
Old Mar 25, 2004 | 07:52 PM
Ri5e's Avatar
Default Re: JDM H22 O2 Sensor Wiring? (BG Boost)
Old Mar 25, 2004 | 07:58 PM
Kataku2K3's Avatar
What exactly are you connecting them too? Just wiring it into your harness?
White = oxygen sensor signal
Yel/Blk = IGN 12V+
Grn/Wht = sensor ground (ties into your TPS, ECT, IAT, and SG2 at the ECU)
Org/Wht = oxygen sensor heater control (ECU switches this line to ground over the input IGN 12V+ (yel/blk wire) turning on your O2 heater)
Modified by Kataku2K3 at 8:44 AM 3/26/2004
Old Mar 26, 2004 | 07:43 AM
Jason kiDD's Avatar
Default Re: JDM H22 O2 Sensor Wiring? (Kataku2K3)
That is correct.
Davi_Vtec
Dec 23, 2012 01:26 PM
robbizza
Aug 29, 2006 08:58 PM
the soL that could
10
Feb 16, 2006 10:44 AM
Ri5e
Mar 25, 2004 10:05 PM
