O2 Wiring Diagram?
Old Mar 25, 2004 | 11:12 AM
Ri5e's Avatar
Default O2 Wiring Diagram?
The JDM H22 Harness:
Yellow/Black
Green/White
Orange/White
Solid White
And the O2 Sensor:
Two Black
White
Green
I did a search and I could not find out which one to connect to?
Old Mar 25, 2004 | 12:12 PM
raser5050's Avatar
Default Re: O2 Wiring Diagram? (BG Boost)
http://icelord.net/honda/repair/
more wiring diagram
Old Mar 25, 2004 | 12:37 PM
Ri5e's Avatar
Default Re: O2 Wiring Diagram? (raser5050)
It's a P13 OBD1
The white wire is leading back to B12 on the ECU?
White/Green wire to D22
Yellow/Black to A2
Modified by BG Boost at 2:19 PM 3/25/2004
Old Mar 25, 2004 | 07:53 PM
Ri5e's Avatar
Old Mar 26, 2004 | 08:51 PM
mattmw88's Avatar
where does the orange wire go to on the ecu?
also did you have any luck figureing out which wires go to which? Thanks a lot
Old Apr 5, 2004 | 06:41 PM
mattmw88's Avatar
Default Re: O2 Wiring Diagram? (mattmw88)
did a little research and found out that :
Solid white wire goes to D4 on ecu
orange/white wire goes to A6 on ecu
the yellow/black wire goes to the resistor box and IAC valve
the green/white goes to the egr lift sensor and the D22 as well
By the way A2 on the ecu is a yellow only wire that goes to injector 4
B12 on the ECU is a white wire going to CYP sensor
Let me know if you want me to scan a copy of the page in the OEM service manuel, it might take a little while, but I can do it. Hope this helps
Oh, and I couldn't, for the life of me figure what wires actually went to the O2 sensor(let me know if you can figure this out), all I know is that in the book the wires go in order as follows:
wht
grn/wht
yel/blk
orn/wht
Old Apr 5, 2004 | 07:37 PM
Behan's Avatar
i don't have an exact answer to your question but this may be of some help. On the usdm o2 sensor, the white wire is the signal wire, the two black are heater wires and the green is a ground.
good luck
Ahknodd
Sep 17, 2006 08:48 PM
Ri5e
Mar 25, 2004 10:05 PM
jisecup
Jul 9, 2003 02:53 PM
raceACCORDingly
Jan 7, 2003 05:31 PM
ImprtTunr
Mar 26, 2002 05:13 AM
