Accord 01 @ 30K
Old Mar 25, 2004 | 09:12 AM
AQ01's Avatar
Default Accord 01 @ 30K
My 01 accord has just passed 30K miles.
Here are what I plan to do on the car:
1. replace spark plugs. What are the part number for this?
2. drain and replace transmission filter
3. drain and replace coolant
4. replace air filter
Anything else I need to do?
Thank you much,
Viny
Old Mar 25, 2004 | 11:42 AM
iam7head's Avatar
Default Re: Accord 01 @ 30K (AQ01)
valve adjustment
alignment(if needed)
oil change
brake pad/rotor inspection
brake fluid change(yes, i said brake fluid)
sparkplug number is in your manual, or just go to autozone for it.
brake booster check
check pcv valve
tires rotation, balance if needed
Old Mar 25, 2004 | 03:01 PM
ben95ex's Avatar
Default Re: Accord 01 @ 30K (iam7head)
the newer F23 engines don't need valve adjustments until 100,000 miles.
Old Mar 25, 2004 | 06:16 PM
Beach Accord's Avatar
Default Re: Accord 01 @ 30K (ben95ex)
dont need new sparkplugs, just wasting your money. they are 100,000 mile platinums.
you need
drain and fill oil and filter
tranny fluid change
change in-cabin pollen\dust filter
alignment\tire rotation\balance
lube all recommended points
check cv joints and boots
brake pad\rotor\hoses inspection
bleed brakes
listen for noisy valves....if so then valve adjust
all this you can do yourself and it will save you money....with the right tools howeveer
and thats it
-chris B
Old Mar 26, 2004 | 05:24 AM
AQ01's Avatar
Default Re: Accord 01 @ 30K (Beach Accord)
Thank you for quick replies.
So I don't need the valve clearance and change the spark plugs.
What are your recommend on where to get the power steering fluid? Do I have to get it through the dealer?
Thanks
Old Mar 26, 2004 | 07:28 AM
oh yeah coolant flush as well.......buy only honda fluids. the dealer has them all.
nukem384
Mar 16, 2010 07:20 AM
hometheaterman
Jan 30, 2008 03:44 PM
sony224422
Feb 20, 2006 03:54 PM
RUBZERK
Sep 18, 2003 09:01 AM
trustbuddy
Feb 26, 2003 12:17 PM
