what axles i use for my b16 swap into my 91 civic si
i'm buying a complete first gen b16 motor from and i was told that the axle that come with them i can't use in my 91 civic si if that is true what axle do i have to use that will fit in the b16 first gen motor and in my91 civic si can i use the axle that i have from my 91 civic si
the axles can work just fine, you may have to remove the dust ring. You need to keep the axles with the corresponding intermediate shaft. There's the JDM setup and the 90-93 integra setup either is fine, they just have slight differences in axles/int. shaft lengths.
hasport.com and search here for more.
http://www.raxles.com good ****......made just for swap.
pnwjdm
Dec 23, 2012 08:57 PM
