Numerous parts for sale....
Old Mar 25, 2004 | 08:46 AM
Jason kiDD's Avatar
Default Numerous parts for sale.... Civic/Lude/Accord
93 Civic Rear Glass $150
91 Accord Front & Rear Tan Seats $200
98 Lude AC Air Compressor $100
8 Point Mild Steel Roll Cage w/ Brackets $300 For EG
93 Civic MC/booster & Prop Valve $100
95 Integra GS MC $50
93 CX Cluster $40
91 Accord MT Cluster $90
98 h22 VSS $40
93 Civic Main Relay $20
h22/f22 Front wishbone mount $75
98 h22 Crank Pully $40
93 Civic stock headlights (glass) $50
PM or email me @ jdjoseph2000@hotmail.com for details
Modified by Jason kiDD at 1:26 PM 3/25/2004
Modified by Jason kiDD at 5:14 PM 12/14/2004
Old Mar 25, 2004 | 08:57 AM
19civic93's Avatar
Default Re: Numerous parts for sale.... Civic/Lude/Accord (Jason kiDD)
FYI: A brand new 93 Civic Main Relay cost $56 at Honda. You might wanna lower your price on that. Those relay's are repairable by desoldering and then resoldering all the contacts the board. I wouldn't pay more than 15 bucks for a used one.
Old Mar 25, 2004 | 09:26 AM
Jason kiDD's Avatar
Default Re: Numerous parts for sale.... Civic/Lude/Accord (19civic93)
Thanks edited..
And a relay is a switch just soldering connections will do nothing for you if the switch went bad..
Old Mar 25, 2004 | 10:56 AM
19civic93's Avatar
Your wrong on that one. I fixed mine. The main relay is a dual relay or 2 relays in one connected by a circuit board. The purpose of this relay is to supply power to the fuel pump. The first half of the relay powers up the computer and the second half turns on the fuel pump. When the computer senses that the key is on, stater is engaged, or senses a tach signal the fuel pump will turn on. The problem with this relay is not the actual relay going bad but the solder connections on the board. The bad connections are called dry joints which causes a bad connection. Dry joints will cause your car to not start intermittently in hot weather until it gets worse and doesn't start at all. The fix is to desolder these dry joint or all the joints and resolder them.
Old Mar 25, 2004 | 11:32 AM
Jason kiDD's Avatar
Okay I am now learned on the subject, thanks for the free bumps..
Old Mar 26, 2004 | 06:37 AM
Jason kiDD's Avatar
Bump again..
Old Mar 26, 2004 | 07:35 AM
Jason kiDD's Avatar
Midday bump..
Old Dec 14, 2004 | 01:14 PM
Jason kiDD's Avatar
bump it up..
Old May 24, 2005 | 05:27 AM
Jason kiDD's Avatar
Bump
new-world
May 6, 2013 01:41 PM
D15Bbigred
Oct 30, 2006 08:41 AM
Jason kiDD
Aug 5, 2005 11:45 AM
