96-98 ex ecu and 99-00 ex ecu interchangability?
Old Mar 25, 2004 | 04:11 AM
igo4bmx's Avatar
Default 96-98 ex ecu and 99-00 ex ecu interchangability?
after buying a "99 ex ecu" from ebay it seems that it will not work properly on my 2000 ex civic (which is currently getting an auto to manual transmission swap right now)
it plugs right up but the car won't start.
anyone know if these two ecus are interchangable to some degree (ie they should both be able to start up my car and let it function, but one throws a CEL)
I thought that these two ECU's had different plug configurations which would make only one of these fit my 2000 civic.
does it seem like a bad ecu or the wrong ecu?
Old Mar 25, 2004 | 04:15 AM
b16 matt's Avatar
Default Re: 96-98 ex ecu and 99-00 ex ecu interchangability? (igo4bmx)
that shouldnt have any probkems interchanging. Unless your puting a manual ecu in an auto or visa versa.
Old Mar 25, 2004 | 04:24 AM
igo4bmx's Avatar
Default Re: 96-98 ex ecu and 99-00 ex ecu interchangability? (b16matt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt &raquo;</TD></TR><TR><TD CLASS="quote">that shouldnt have any probkems interchanging. Unless your puting a manual ecu in an auto or visa versa.</TD></TR></TABLE>
i'm putting a manual ecu in my 99% done 5 speed swap.
Old Mar 25, 2004 | 06:12 AM
igo4bmx's Avatar
bump
Old Mar 25, 2004 | 07:51 AM
EE_Chris's Avatar
Default Re: (igo4bmx)
96-98 is one ECU, 99-00 is the other type...so yes, if you do have a 99 Ex ECU, it should work just fine on your 00.
However, seems as how you went from auto-manual, have you done the IACV fix?
Old Mar 25, 2004 | 07:55 AM
igo4bmx's Avatar
Default Re: (EE_Chris)
im not sure yet, dan from fuzion (member here) is doing the work
Old Mar 25, 2004 | 03:56 PM
igo4bmx's Avatar
BUMP for more help
IACV IS JUMPING LIKE CRAZY!
IntegraCF21
Oct 9, 2011 04:22 PM
Agent_STFU
11
Aug 24, 2005 02:45 PM
helpme659
Mar 12, 2005 01:24 PM
Crimson490
Sep 3, 2003 05:58 PM
turbod16y8
Mar 8, 2003 04:49 PM
