Bang for the Buck
Old Mar 24, 2004 | 08:40 PM
Memo6453's Avatar
Default Bang for the Buck
I have a 2001 base prelude with i/h/e/vafc what would be a nice mod considering g0in f/i within 6months...i need a little more till then... any go0d websites to0 browse?
Old Mar 24, 2004 | 09:11 PM
SUB-0 H23's Avatar
Default Re: Bang for the Buck (Memo6453)
upgrade clutch and flywheel
Old Mar 24, 2004 | 09:28 PM
Firedrake's Avatar
Default Re: Bang for the Buck (SUB-0 H23)
Depends how much you're looking to spend:
Tranny package: $1800+ would be flywheel, clutch, quaife LSD
Fuel/Control package: $1500 Hondata s200b, injectors, rail, regulator, intank pump
Turbo Exhaust: $600 3inch mandrel with magnaflow muffler
Traction control: $350 24.5x8.5x15 slicks on stock rims
Cool stuff: Forbidden MS shortshifter, various gauges (good EGT gauge from greddy or apexi recommended), battery relocation to trunk, etc
That would be stuff to buy assuming you're doing up a nice kit. If you're just bolting on a drag kit or something you need to start saving for a new motor
Brian
Old Mar 24, 2004 | 10:05 PM
Icey112's Avatar
nitrous is buy far the biggest bang for your buck.
Old Mar 24, 2004 | 11:10 PM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUB-0 H23 &raquo;</TD></TR><TR><TD CLASS="quote">upgrade clutch and flywheel</TD></TR></TABLE>
I do that if you havent done so already. You're going to need it when you go F/I anyways since the stock clutch will probably last you a few days if that.
Old Mar 25, 2004 | 01:18 PM
Memo6453's Avatar
n-e-one suggest cam gears or pulleys? something under $500? i am planning to get the greddy bolt on kit wit the type 24 i/c so i dont wanna spend to0 much $$$ on something i wont gain from...what do you people think about the greddy kit?
Old Mar 25, 2004 | 01:21 PM
sigfan2340's Avatar
If you are looking for a low cost bank for the buck mod, pulleys would be the way to go. You can find a used set for around $100 or new $175. Not a bad mod to do. Probably at this point would be best bang for little $$$$$
Old Mar 25, 2004 | 01:26 PM
UA6 BALLER STATUS's Avatar
Default Re: (sigfan2340)
Light weight wheels with sticky tires or lsd tranny.
Old Mar 25, 2004 | 02:52 PM
PirateMcFred's Avatar
try JATO bottles. Cheap from military surplus.
Old Mar 25, 2004 | 03:20 PM
Daemione's Avatar
Default Re: (PirateMcFred)
If you're going turbo, upgrading your clutch should be the first thing you do.
SI BOII
Mar 24, 2007 10:37 AM
jDMJeRk
Feb 1, 2006 09:03 PM
djvtoner
17
Jun 25, 2004 09:26 PM
Toretto
May 10, 2003 03:50 PM
infamousALLMTR
Jun 28, 2002 12:55 PM
