Paranoia? Is this going to affect head gasket seal?
I'm about to assemble my B18A bottom end, and I noticed a scratch on the deck of the block. Must have got bumped while at the machine shop. Anyway, does it look like a big deal? It's on the deck near the water jacket; I can catch a fingernail in it, but it is not really all that deep. There is a knick on the outer edge of the sleeve as well. Will this be a problem? It's going to be a turbocharged application, if that matters, running about 10 psi.
Thanks for any input.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paybac4223 »</TD></TR><TR><TD CLASS="quote">The block side looks fine but the piston wall looks a tad suspect...if you are going to be running 10lbs of boost that could lead to a crack forming on that sleeve</TD></TR></TABLE>
It's really a tiny knick.. more like a bump/depression. I don't like the sound of that though.
Funny, I was more concerned about the block deck.
Thanks for the quick reply.
All opinions welcomed.
Funny, I was more concerned about the block deck. Thanks for the quick reply.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paybac4223 »</TD></TR><TR><TD CLASS="quote">I've heard mixed opinions about block guard, however i have never tried one...</TD></TR></TABLE>
I have a block guard welded in on my fully built LS and I really dont notice a difference.
I dunno bout those scratches there, as far as the cylinder goes i think it should be ok. but the outer one you might want to get fixed. if you can catch your finger nail in it, it might cause problems with the seal, but you might be able to just attach the head gasket with some copper gasket sealant filling in the hole. I think that should work...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">can u feel the scratch when you run your finger nail on it??</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 »</TD></TR><TR><TD CLASS="quote">also are you planning on using a block guard to alleviate cylinder distortion</TD></TR></TABLE>
Wasn't planning on that.
Thanks for the replies, guys.. Machine shop recommends a deck job (from my description over the phone)...
Yes.
MR.johnson
Jun 15, 2012 07:48 AM
7rrivera7
Dec 21, 2007 06:57 AM
IntegraGSR(-1)
Feb 13, 2006 10:37 AM
swlabhot
May 23, 2003 11:09 AM
