Big Cams Oversized Vales but sock bottom end?
no, but it's kinda pointless unless your doing a bottem end buildup later on. Is this on a B or D? You really dont need oversized valves on a D unless it's turboed. I'd just do cams if your not building the bottem later on
Unless the higher lift on the new cams causes the valves to hit the pistons, it will not be a problem.
I assume what you mean by stock bottom end is one you have had rebuilt/blueprinted?
I am running a H23
And not the motors not rebuilt or blueprinted would i need this done and why?
Why would this make may car slower and i got it done at JG engine dynamics and there .5mm oversized
Modified by PreludeV8Smoka at 12:15 PM 3/25/2004
I don't know who makes a oversize valve for the H23, but if you did find a way to do all this it would make your car slower than it was stock.Guaranteed
