zc swap into dx:what axles should i use??
im doing a dohc zc swap into my 91 dx hatch. the motor is from a 89 teg ls. people have told me different things about the axles. i will be using the zc tranny, so which are the best axles to use, which will fit right in with out having to do any major adjusments??
yea the rear mount is not the same as on our 88-91 also if you like zc try
http://www.thezcr.com
its a site dedicated to the zc just more info for you
the motor from a 89 ls is considered a zc motor, just not the jdm one. i will be using the 89 ls tranny. i was thinking about usint the si axles, but then i wasnt sure they were gonna fit in my dx hubs. any other suggestions??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batman21 »</TD></TR><TR><TD CLASS="quote">the motor from a 89 ls is considered a zc motor, just not the jdm one. i will be using the 89 ls tranny.</TD></TR></TABLE>
I say, I say...you boy, you are mistaken. T'ain't no ZC...that my boy, is D16a1.
it might be considered a usdm ZC but it won't fit in your car.
if that motor really came from a 89 teg, then avoid it at all costs. listen to what we say.. save yourself some major headaches.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batman21 »</TD></TR><TR><TD CLASS="quote">and yes some people consider it the usdm zc.</TD></TR></TABLE>
Can I start calling my Si a usdm SiR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">it all depends on whut transmission u are using.
What he said.
What he said.
