B-series parts on ZC?
Old Mar 24, 2004 | 04:57 PM
beavis's Avatar
Default B-series parts on ZC?
I have a DOHC ZC and i have a few questions about what B-series parts fit on my ZC, Please bare with me because I dont know which ones fit and which ones dont. Heres the list of them:
1. Cams and cam gears
2. Throttle body
3. Intake manifold
4. Pistons
please answer to this it would really help me out becauase it is hard to find what parts that fit on ZC's and I'm pretty sure there are other ZC owners out there with the same questions. Thanks guys
Old Mar 24, 2004 | 05:14 PM
VtecKiDD's Avatar
Default Re: B-series parts on ZC? (ZCed89hatch)
Throttle body will fit, anything b series IE type-r,gsr,b16, etc
Pistons-absolutly not, no b series will fit
Cams-absolutly not, no b series will fit
Cam gears- any b16/gsr/type-r/LS aftermarket cam gears work (skunk2 is good)
intake manifold-no b series will fit
you need to learn that for most 99% of the time B series stays with Bseries, and D series stays with D series. Try EXOSPEED for camshafts, any aftermarket pistons company, and a custom port/polish on your intake manifold will work. good luck
Old Mar 24, 2004 | 05:56 PM
91civicDXdude's Avatar
if the dohc zc intake manifold has the samne throttle body bolt pattern as a d16a6, then a b series throttle body will not fit without some modification.
92+ intake manifolds from D series will accept B series throttle body.
Old Mar 25, 2004 | 02:11 PM
beavis's Avatar
Default Re: B-series parts on ZC? (VtecKiDD)
thanks man
janz3n
Mar 29, 2007 04:39 PM
1SIKCRX
Apr 1, 2004 06:23 PM
JDM_4_LIFE
Mar 19, 2004 09:31 AM
messeduprex
Oct 9, 2003 05:07 PM
It's*BOLO!!
Dec 21, 2002 09:24 PM
