few wiring ?'s about B16 swap into 90 CRX
Old Mar 24, 2004 | 01:44 PM
wickedEFguy's Avatar
Default few wiring ?'s about B16 swap into 90 CRX
well first off my car is multi-point since it's a Si so I don't need info on DPFI->MPFI.
I'm ready to hook up the 4 extra wires but from what I understand that the JDM ECU does not have ELD wiring. Now can I just splice into the wires that are already pre-wired for the PM6 or should I just swap out the pins and tape them off?
This is what I've found so far:
VTEC pin assignments:
Pin A8==Spool Solenoid Valve (grn/wht)
Pin B5==cylinder head Oil Pressure Switch (blu/blk)
Pin B19=Knock Sensor (wht)
Pin C8==2nd Oxygen Sensor (orn)
USDM "Si" pin assignments:
Pin A8==Nothing
Pin B5==To Alternator (part of Electronic Load Detector [ELD] system)
Pin B19=ELD system
Pin C8==Nothing
Old Mar 24, 2004 | 04:13 PM
bump, someone has got to know
Old Apr 7, 2004 | 09:33 AM
88 turbo crx's Avatar
Default Re: (wicked B16)
dont splice, if your wiring info is correct, it sounds right, ill check later tonight, but repin them and tape the other wires off
Old Apr 7, 2004 | 11:50 AM
Default Re: (88 turbo crx)
thanx for the info......I already cut and added wires.
wickedEFguy
May 20, 2020 03:51 PM
God-Driven
May 20, 2007 08:50 PM
takeheed
Sep 16, 2002 03:50 PM
ricodemus
May 24, 2002 05:04 AM
