What is a 92 SI COMPRESSION supposed to be on each cylinder?
Old Mar 24, 2004 | 01:07 PM
andrep450's Avatar
Default What is a 92 SI COMPRESSION supposed to be on each cylinder?
Hi, I might be buying a 92 SI auto tomorrow. Please tell me what compression should each cylinder have? Thanks.
Old Mar 24, 2004 | 01:08 PM
andrep450's Avatar
Default Re: What is a 92 SI COMPRESSION supposed to be on each cylinder? (andrep450)
Also, what other things should I note after the pre-purchase inspection has been completed? Thanks.
Old Mar 24, 2004 | 05:08 PM
andrep450's Avatar
Hi, can someone please answer my question?
Old Mar 24, 2004 | 05:45 PM
homesauce's Avatar
I am gonna guess high 180+ psi on each cylinder, but I don't drive an H23, but the key is to have constant numbers throughout the cylinders.
Old Mar 25, 2004 | 05:30 AM
rkonfire's Avatar
Default Re: What is a 92 SI COMPRESSION supposed to be on each cylinder? (homesauce)
Make sure the auto tranny is in good shape. Check the radiator and make sure there isn't a crack right near the lid (that is a most common place for these radiators and it can be spendy to put a new radiator in unless you do it yourself). See if you can get receipts on timing belt/water pump if they were done. If you hear a lot of ticking noise while it's at idle then it needs a valve adjustment. There's a cam seal that has a tendency to leak on the rear left side of the valve cover if you're looking at the engine from the front.
Obviously, the car's used and it will have its problems. However, that doesn't mean you shouldn't buy it! If you see some of the above problems and point them out, use the problems to get a better deal on the car.
JudahDamian
Dec 4, 2018 07:30 PM
DCiFound
Sep 7, 2014 10:43 PM
mimog3
Nov 19, 2012 07:26 PM
roach4201986
Jul 28, 2011 05:43 PM
Its me DUB
Apr 2, 2005 11:59 PM
