experience with N2O
Old Mar 24, 2004 | 12:00 PM
Jose.'s Avatar
Default experience with N2O
ive never had a car or even been in a car that has n2o, but im thinking of getting it. im thinking of a 50 shot. is there anything i should look out for? also, do all the brands have the option of automaticlly engaging only at full thorttle? thanks for any info on it.
btw....b16a
Old Mar 24, 2004 | 12:29 PM
vteccrx909's Avatar
Default Re: experience with N2O (d-town hatch)
i dont know what you have done to the motor but all nitruos kits are made to work on a stock motor the one thing you have to do is change to a colder spark plug. on an NGK plug you would need to go non platnum and the plug # is BKR7E, or you could go with a DENSO Iridrum plug they are more money but they are worth it they will last you much longer. and a 50 shot will be fine with just the plugs but if you wanna go like 75 or a 100 you would need to put in a new fule pump i would go with a walbro 255lph pump. on the kits you could go with any kit but you make the best wheel power with like an NX kit or a ZEX kit
Old Mar 25, 2004 | 11:39 PM
shizty20's Avatar
Default Re: experience with N2O (vteccrx909)
Yeah vteccrx909 is right on, If I was you id get a fuel pressure regulator just to be safe, but not necesarry unless your running anything over 60shot, then you would also need too look an after market fuel pump and maybe retard timing. But definatly get the colder plugs, and DO NOT get a Zex kit, the are the easiest to install but they suck. They make the lowest hp and they are all dry kits, which tend to overload the injectors and cause them to fail, if this happens while spraying, bye bye engine! Get a NOS wet kit or NX. I used to have a NX wet kit on my Si before it got stolen and I was very happy with it. Just do some reaserch and use common sence, nitrous is just as safe as other forms of FI if used properly. Hope this helped.
SiR Inspired ED7
17
Mar 9, 2010 08:36 PM
harveyep3
Engine Management and Tuning
Jan 20, 2009 05:12 PM
sfwdcrx
Sep 8, 2007 07:08 AM
Clairvoyant
Sep 11, 2006 01:35 PM
crxzcracer
Sep 10, 2004 11:26 AM
