coil overs without shocks? Good idea?
Old Mar 24, 2004 | 11:24 AM
indyjones's Avatar
Default coil overs without shocks? Good idea?
There's a couple companies out there selling fairly inexpensive coil overs. Cosmo Racing, for example, sells a double spring kit for only 150 Dollars. I won't need it for racing, mostly for looks. I've got a 90 Accord with body kit. Will the springs be firm enough so that I don't need new shocks to go along with the coil overs?
Also, how hard will the installation be. Can I do it myself?
Thanks, Indy
Old Mar 24, 2004 | 11:26 AM
FatJoe's Avatar
Default Re: coil overs without shocks? Good idea? (indyjones)
you get what you pay for... thats all i gotta say...
if you are knowledgable and have the proper tools you can install them yourself...if you dont know what you are doing...dont try... ull hurt urself.
get new struts with those coilovers...they will provide for a better ride.
Old Mar 24, 2004 | 11:56 AM
.bagged's Avatar
Welcome to HT...Try reading the Guide to basic accords...at the top of the forum.. iam7head did a great write up on suspension..read that and your question will get answered...
Old Mar 24, 2004 | 12:09 PM
jwogen1's Avatar
Default Re: coil overs without shocks? Good idea? (baGged93aCcord)
after you read the basic guide, and you have some follow up questions then fire away! i cant stress how important it is to the ride quality to upgrade your struts when lowering your vehicle. thats it im out
Old Mar 24, 2004 | 12:38 PM
fw190bvi's Avatar
Default Re: coil overs without shocks? Good idea? (jwogen1)
if ur gonna get "stand alone" coilovers....the ONLY ones worth the money are the Ground Control brand (uses eibach springs....)
PLEASE read the GUIDE TO BASIC ACCORDS
welcome to HT
Old Mar 24, 2004 | 09:19 PM
'00Accordster's Avatar
i read the basic guide but i myself am still unsure on wether i need shocks and struts or just struts. Could someone explain it to me. (i did a lot of searching by the way and couldnt find an answer)
Old Mar 25, 2004 | 01:59 PM
iam7head's Avatar
Default Re: coil overs without shocks? Good idea? (95Accordster)
because the stock shock is built to control the stock/oem spring's damper and rebound cycle, which most likely none of the aftermarket spring(or worst, coilover) carry that same spring rate.
or in my ghetto term, it's gonna be hella bouncy
JDMKid71
Suspension & Brakes
Aug 7, 2006 08:25 PM
fivelugsteelies
Mar 9, 2005 08:50 AM
elgs
Mar 10, 2004 03:11 PM
Gordie
Aug 24, 2003 08:20 PM
jdmCivic925
May 17, 2003 08:15 PM
