94 DX EG hatch w/ turbo b18b for sale.......
Old Mar 24, 2004 | 08:43 AM
1.8t's Avatar
Default 94 DX EG hatch w/ turbo b18b for sale.......
SOLD!!!!!!
I go to school in Auburn, Alabama. I live in Atlanta, Georgia. VIN# is 2HGEH2365RH511420. I will be gone on Spring Break from the 25th through the 4th, so if you pm during that time, thats why I haven't gotten back to you. I am looking to get sold and yes, I lose a good bit of $$$ with that price.
Reason for selling car is because I have 2 cars and can't afford both, there is no other reason(other than the fact I want an R6)Car has NO rust. The chassis has 200k miles on it and the swap has exactly 80k miles on it. The swap has had Mobil 1 5w30 syn ever since the motor went into the car and the car does NOT burn oil. The comp. is absolutely perfect and has been ever since boosted(only turbocharged for the past 2k miles), we can even comp. check the car for the potential buyer if need be. The body is in a 6~7/10 shape, could use a paint job and it dents and dings. The car will come with a new rear bumper that is still in bubble wrap. The car is tuned on 6psi and 10psi. On 6psi it made 198.8whp and 170.7wtq, I have the dyno sheets and the a/f readouts for proof. The car has yet to be dyno'ed on 10psi as the car was wideband tuned w/ the hondata on the street. The car has been tuned VERY conservatively. On 10psi, it runs 11.0 a/f during boost with 20deg of total timing on top. The setup reads like this:
95 B18b
Maxrev manifold
Maxrev downpipe
Tial 38mm wastegate
T3/T04e- 60 trim, .63a/r
Custom Piping
Johnnyracecar.com 6" IC
DSM BOV
DSM 450cc injectors that have been cleaned and balanced(I have the flow sheet for proof)
Flamenco T oil feed/return kit
NGK BKR7e-11's gapped at .32(no missing)
Hondata S200b tuned
Autometer oil pressure and boost guages inside. Its a 3 guage pillar pod, so the new owner can put whatever he/she wants to in there.
Walbro 255lph fuel pump
Turbo XS HP manual boost controller
I put carpet in the car, a clock from a coupe, and a center arm rest from a coupe. The car is currently open DP, but I had a 3" custom crush bent exhaust made that is not on the car right now. The exh. rattles against the heat sheilds, so I took it off to pinpoint the rattles and to fix them. The cars rear plastic trim will also come w/ the car. Those were taken out so I could clean the car. The new owner can even have the D15b7 that came out of the car(ran perfect) for free. The tranny has NO grinds, the car has never been revved above 7k rpms, but I have the rev limiter set at 7300rpm just to help prevent from hitting it(when you hit the rev limiter on hondata, it cuts fuel and can cause the car to detonate). The cars best time on slicks was a 13.1@104.1mph and the best street tire time was a 13.8@110.9mph. Both runs were on 10psi. On 6psi, I achieved a 13.8@105.25mph. The car has been drag raced 3 times. Once on 6psi, once on 10psi w/ street tires, and once on 10psi w/ slicks. Clutch DOES NOT slip at all, car runs perfect. The motor has a new timing belt and water pump.
Now, to the faults of the car. The car DOES NOT have A/C. The car needs a dumptube made, I have the flange, all the new owner needs to do is have an exhaust shop bend them a tube or make on. The cars radio recieves power, but its only static, it is more than likely an intenna thing. The car has some dents in it and I had to cut the front bumper to fit the piping as you can see in the pics. Mechanically, the car is as sound as they come. I did all the work myself as no one touches my cars other than myself.
Here are some pics:
http://www.auburn.edu/~mcgowmd/100_0164.jpg
http://www.auburn.edu/~mcgowmd/100_0166.jpg
http://www.auburn.edu/~mcgowmd/100_0168.jpg
http://www.auburn.edu/~mcgowmd/100_0169.jpg
http://www.auburn.edu/~mcgowmd/100_0170.jpg
http://www.auburn.edu/~mcgowmd/100_0171.jpg
Edit: And yes, there is a shitload of pollen on the car.....damn plants orchestrated a surprise attack this year.
Another edit: Here is a video of the guage cluster on 10psi, 50-115mph. Right click and save as. Need quicktime to view.
http://www.auburn.edu/~mcgowmd/100_0039.mov
Modified by 1.8t at 5:55 PM 3/24/2004
Modified by 1.8t at 6:18 PM 3/24/2004
Modified by 1.8t at 11:05 PM 3/26/2004
Old Mar 24, 2004 | 11:14 AM
1.8t's Avatar
Default Re: 94 DX EG hatch w/ turbo b18b for sale....... (1.8t)
up
Old Mar 24, 2004 | 11:31 AM
94sisol's Avatar
IMed ya.
Old Mar 24, 2004 | 01:58 PM
1.8t's Avatar
Default Re: (94sisol)
Replied back to your pm. Comp. checked the car again to day, March 24th. Plugs looked GREAT comp. numbers read as follows:
205, 203, 205, 205 psi of course
Old Mar 24, 2004 | 03:58 PM
maxpsi's Avatar
Default Re: (1.8t)
I can vouch for this car. If it can hang with a 12 second C5, then it's pretty fast. Great price too.
Old Mar 24, 2004 | 05:44 PM
bikeman311's Avatar
hey whats up please email me or call me at 304-633-8459 thanks i am very intrested in the car and would like to talk /w you
noah
Old Mar 24, 2004 | 05:52 PM
TRAY's Avatar
Default Re: 94 DX EG hatch w/ turbo b18b for sale....... (bikeman311)
nice car and super deal......sleeper
Old Mar 24, 2004 | 06:09 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: 94 DX EG hatch w/ turbo b18b for sale....... (TrayDay2K1)
This car is crap I saw it in person. Nobody buy it
Just kidding guys. This is an awesome car that was well built and safely tuned. I've driven it myself and it hauls. It's trap speed does not do it justice. From a roll it walked an LS1 that was trapping 114mph.
Too bad for you guys that I'm going to buy it first.
< is bumping a car he is planning on buying because he is dumb.
Old Mar 24, 2004 | 07:17 PM
94sisol's Avatar
If Active can't get it then I HAVE DIBS! No offense but I hope your loan get denied Active haha.
Old Mar 24, 2004 | 07:29 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94sisol &raquo;</TD></TR><TR><TD CLASS="quote">If Active can't get it then I HAVE DIBS! No offense but I hope your loan get denied Active haha.</TD></TR></TABLE>
Lol. Well if my bank wasn't gay and would actually show the paypal deposited amounts so my spending limit would be lifted I could wire him the money right now and joo would be owned!!!! Well actually the hatch would be owned.....by me.
Old Mar 24, 2004 | 07:34 PM
94sisol's Avatar
Well if I could come down there tomorrow & pick it up & he wouldn't choose you over me then you sir would be owned, actually the car would by ME! Haha...
Old Mar 24, 2004 | 07:42 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94sisol &raquo;</TD></TR><TR><TD CLASS="quote">Well if I could come down there tomorrow & pick it up & he wouldn't choose you over me then you sir would be owned, actually the car would by ME! Haha...</TD></TR></TABLE>
Stop bumping the thread. You are allowing more people to see......dang it!
Old Mar 24, 2004 | 07:46 PM
94sisol's Avatar
Default Re: (ActiveAero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
Stop bumping the thread. You are allowing more people to see......dang it!</TD></TR></TABLE>
BUMP!!!!!!!!!!!!!!!!!!!!! If I can't have it, you won't either....Muhahaha...
Old Mar 24, 2004 | 11:23 PM
RICE POLICE SIP's Avatar
damn good price. good luck wish i had the cash...
Old Mar 25, 2004 | 09:35 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: (Split Image Prez)
LOAN APPROVED! Mwahahaha!
Old Mar 25, 2004 | 10:22 AM
94sisol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">LOAN APPROVED! Mwahahaha!</TD></TR></TABLE>
Can I get a **** you? **** YOU! Bitch...I wanted that car so bad too...
Old Mar 25, 2004 | 10:47 AM
JDMisGOOD's Avatar
quick little Eg...if i had the extra $$$ i would buy!
Old Mar 25, 2004 | 04:11 PM
zer0.'s Avatar
Default Re: (JDMisGOOD)
bump for a car that could rip mine a new *******.....good price too!
Old Mar 25, 2004 | 06:52 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: (zer0_2_6ixty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0_2_6ixty &raquo;</TD></TR><TR><TD CLASS="quote">bump for a car that could rip mine a new *******.....good price too! </TD></TR></TABLE>
No need to bump it. I'll be picking the car up as soon as Micheal gets back from spring break.
Old Mar 25, 2004 | 08:49 PM
94sisol's Avatar
No need to bump it. I'll be picking the car up as soon as Micheal gets back from spring break. </TD></TR></TABLE>
d
i
e
Old Mar 25, 2004 | 08:54 PM
beseman's Avatar
HOLY ***** THATS CHEAP NIKKA BUMP even tho you dotn need it
Old Mar 25, 2004 | 09:21 PM
maxpsi's Avatar
Default Re: 94 DX EG hatch w/ turbo b18b for sale....... (beseman)
Maybe he'll get a better offer and sell it out from under Alero.
Sooooo.................BUMP. hehe
Old Mar 25, 2004 | 09:27 PM
hasback*'s Avatar
F*CK THIEVES!
Default Re: 94 DX EG hatch w/ turbo b18b for sale....... (maxpsi)
that is cheap
Old Mar 26, 2004 | 02:21 AM
94sisol's Avatar
I shall give you $4300 if you meet me half way between there & St. Louis.....
Old Mar 26, 2004 | 02:05 PM
1.8t's Avatar
Sold.
