Cable tranny problem
Old Mar 24, 2004 | 06:23 AM
CRXEE8's Avatar
Default Cable tranny problem
1000 miles after I installed a 6 puck ACT clutch with a CM flywheel I have had problems with 1. and 2. gear. It's like 1. and 2. does not exist. Down shifting from 3. is really hard to 2. and even when I'm not driving both gear block. The tranny has just been cleaned and 1. and 2. syncho have been replaced. There is no problem with 3., 4., 5. and reverse. I'm thinking it's a clutch problem. Any suggestions?
Thanks
Old Mar 24, 2004 | 11:06 AM
fearless_dsm's Avatar
Default Re: Cable tranny problem (CRXEE8)
maybe your shift linkage is messed up..
Old Mar 24, 2004 | 08:04 PM
fox297's Avatar
Try tighten up the cable.
Old Mar 25, 2004 | 05:25 AM
Sliced Beard's Avatar
Default Re: Cable tranny problem (fox297)
sounds to me that your clutch is not completely disengaging
if that is the cas you need to tighten up you cable otherwise you are gonna wear your brand new syncros down super fast
Old Mar 25, 2004 | 09:13 AM
CRXEE8's Avatar
Default Re: Cable tranny problem (dirtyd463)
Yes I have tried tighten up the cable but the problem is still there. The problem came to days after I got my B20VTEC tuned and I may have caused some damage because the car was not able to transfer the power to the wheels. In 1. gear it was not even making wheel spin but "jumping" because of the stock suspension. One of the engine mounts is damaged so I don't know if the engine sits to low.
dontgodumb
12
Jun 15, 2006 09:17 PM
Honda Crx
May 29, 2006 07:39 AM
joeyandhiscrx
Jan 24, 2004 09:16 PM
