Swap problem not starting
Old Mar 23, 2004 | 10:31 PM
89 JDM CRX's Avatar
Default Swap problem not starting
So tonight i went finish my b18b swap into my 89 crx Si tonight , i'm using a 0bd0 to 0bd1 conversion harness , got the proper distributer wiring and stuff in check , finished bolting things together went to crank it , it cranks but no fuel pump sound, no relay clicking sound, so we hard wired the pump, and it worked, but still no injector pulse...
Anybody else run into this problem or have any suggestions ? And also can anyone tell me exactly where my main relay is ?
Old Mar 23, 2004 | 10:52 PM
civickiller's Avatar
Default Re: Swap problem not starting (89 JDM CRX)
take out your little coin tray and look to the left, you should see something that says main relay, its alittle black box thats about 3 or 4 inchs long and has a metal bar on it, then you go from underneath, i used a open end to take off the one screw.
make sure you test yoru wiring to make sure your relay is getting power in the first
Old Mar 24, 2004 | 06:22 AM
89 JDM CRX's Avatar
Default Re: Swap problem not starting (civickiller)
thanks i'll check that out
See Are X
May 16, 2008 05:25 PM
GSRinmyCRX
20
Jul 26, 2006 05:15 PM
ringgold
Sep 28, 2005 08:23 PM
89 JDM CRX
Mar 29, 2004 06:50 AM
89 JDM CRX
Mar 24, 2004 06:23 AM
