Definetely did a search, but I want to know the "REAL" reasons.
Old Mar 23, 2004 | 07:42 PM
Drian's Avatar
Default Definetely did a search, but I want to know the "REAL" reasons.
I'm gonna do a rebuild in the near future on my '94 GSR. 150k!!!! Runs good, but I just want piece of mind. Not going ALL out. Only going OEM. So the question is on pr3 pistons in my GSR. I heard it is not worth the money. And I heard that the it wont seat right???? It definetely yeilds higer CR, but what about in the long run? I'm getting a gasket set for the whole motor, bearings, head studs, valve guides, etc. I was going for ITR but I could save ALOT by going for some good used pr3's
P.S
Not looking for ITR's unless they are under a bill.
Need real valid answers.
THANKS!!!!!!!!!!
Old Mar 23, 2004 | 08:27 PM
Drian's Avatar
I know someone knows something about this. Any help would be appreciated!
Old Mar 23, 2004 | 08:37 PM
zilverz's Avatar
Default Re: Definetely did a search, but I want to know the "REAL" reasons. (Drian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drian &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna do a rebuild in the near future on my '94 GSR. 150k!!!! Runs good, but I just want piece of mind. Not going ALL out. Only going OEM. So the question is on pr3 pistons in my GSR. I heard it is not worth the money. And I heard that the it wont seat right???? It definetely yeilds higer CR, but what about in the long run? I'm getting a gasket set for the whole motor, bearings, head studs, valve guides, etc. I was going for ITR but I could save ALOT by going for some good used pr3's
P.S
THANKS!!!!!!!!!! </TD></TR></TABLE>
B16 and B18 pistons are all the same bore size. You get the pistons and the oem rings and it will seal
There is a calculator on Cspeed racing that will tell you what your compression ratio will be with your configuration. GSR = 10:1 soo put the piston you want in the calculator and what head and block your using and it will tell you your new compression ratio
Old Mar 23, 2004 | 08:39 PM
BolivianDc2's Avatar
Default Re: (Drian)
you don't make sense, you are going to rebuild your old motor because of age, but use used parts?
Old Mar 23, 2004 | 08:43 PM
Drian's Avatar
I make perfect sense. Please read. I said I'm on a strict budget. A rebuild is gonna happen sooner or later. Which is better used? GSR pistons of over 150k or pr3 pistons under 40k? Its just like people buying a used DC header or used ITR Cams/valvetrain.
caliBMXer
Jan 8, 2010 01:55 PM
ToK3nDC2
Feb 6, 2008 12:14 AM
ToK3nDC2
20
Feb 5, 2008 09:43 AM
aandrewcc
May 23, 2006 02:40 AM
xplanetearth420x
May 26, 2004 10:16 PM
