88 crx Si with ZC 1.6l DOHC motor swap - wiring harness questions
Old Mar 23, 2004 | 06:56 PM
jonsimo's Avatar
Default 88 crx Si with ZC 1.6l DOHC motor swap - wiring harness questions
Hey guys im about to pruchase an 88 honda crx si with a 1.6l dohc 135hp zc engine, but the car is currently not running, he says that when he did the swap he tried to connect an old wiring harness with a new one but it didnt work. He suggests a new wiring harness from a junkyard or something. First> are these harnesses expensive? Are they hard to install? Will a stock harness work for the zc engine? Are there any how-to sites or posts? Any help would be appreciated. I think this car has good potential and for $600cdn its not a bad deal either. Thanks for any help you guys mite have.
Old Mar 23, 2004 | 11:09 PM
civickiller's Avatar
Default Re: 88 crx Si with ZC 1.6l DOHC motor swap - wiring harness questions (jonsimo)
assuming the interior harness wasnt changed, you should be able to go tot he junk yard and buy a engine harness from a 88-89 civic si and it should all work
Old Mar 24, 2004 | 06:20 AM
jlicrx's Avatar
Default Re: 88 crx Si with ZC 1.6l DOHC motor swap - wiring harness questions (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">assuming the interior harness wasnt changed, you should be able to go tot he junk yard and buy a engine harness from a 88-89 civic si and it should all work</TD></TR></TABLE>
only the 88 Si will plug right in at the firewall - 89-91 had a different connector due to having more wires for the Fast Idle Control Valve - you could use any 88-91 Si if you swapped connectors
Old Mar 24, 2004 | 11:27 AM
Default Re: 88 crx Si with ZC 1.6l DOHC motor swap - wiring harness questions (jlicrx)
oh i thought that 88-89 wiring was the same. sorry about that, thanks for clearing that up and teaching me something new
BigbamaBen
23
Jun 20, 2019 06:55 PM
FloMotion
May 26, 2013 07:41 PM
h22 kamikazi
Jun 12, 2007 04:45 PM
Dspad_91Civic
May 7, 2004 05:12 PM
JDM HYBRID
Mar 22, 2002 02:57 PM
