opinion? 95 ls/vtec trans, has gone bad what would you do?
just wondering how many other trans. fit my engine and if i had say a 90 integra or any b-series
m.t. would that work? tahnk you
if you have a 90 integra, it comes with the ls (b18a) transmission. if should work fine. if you want to eventually want to turbocharger your motor. LS has longer gears in comparison with the vtec trannys. If you are going NA and can change the tranny from a cable to hydro then you can use gsr, si, r trannys. Or you could get the type r last gear (i think) and put it in the ls not sure though.
killerpenguin21
18
Dec 14, 2006 08:23 AM
