440cc Nippon Denso Injectors
Old Mar 23, 2004 | 11:39 AM
slixxracing's Avatar
Default 440cc Nippon Denso Injectors
I recently got some Denso 440cc injectors from a buddy of mine which was used on a H22 motor w/ a p72 hondata s100 w/ boost option. I know that stock h22 injectors require running a resistor box if using a p13 ecu, but if he was using a p72 ecu with hondata equipped, he didnt need to run the resistor box. Anyways, supposly he said they are 440, but as I recall denso never made any 440's, only 450cc (correct me if im wrong). They are the black top injectors and have denso written on the side of them. Here are my questions regarding them.
1. How can I tell if they are peak/hold or saturated injectors? So I can run a resistor box if needed.
2. What would be the cause of running some peak/hold injectors w/out a resistor box?
3. Would the peak/hold injectors have bad idle or even car start?
Old Mar 23, 2004 | 11:58 AM
InjectedPerformance's Avatar
We sell parts.
Default Re: 440cc Nippon Denso Injectors (slixxracing)
Put a fluke on the injectors and ohm them out. If the ohm is like 2-3 that is peak and hold. If the ohm is 11-14 that is saturated.
Old Mar 23, 2004 | 05:22 PM
Default Re: 440cc Nippon Denso Injectors (primo8998)
cool...ill try that.
H22 SL33P3R
Nov 4, 2014 10:52 AM
b16bri
Sep 5, 2010 02:53 PM
columbushatch
Jan 17, 2009 11:08 AM
civicsaremean
Jun 29, 2007 06:17 AM
boost_is_best
Feb 28, 2006 03:45 PM
