93 accord ....HELP (Starting problem)
Engine starts but stops immediately. Did checked the IACV, vacuum, and timing. It will crank, start, but as fas as I let go my key, it will stop(after it started) . I have actually have to hold the key in the ignition, in order for it to run, and it will run fine. Is it the bad ingition switch? How much am I looking at? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8 9 si »</TD></TR><TR><TD CLASS="quote"> Is it the bad ingition switch? </TD></TR></TABLE>
Probably
Probably
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Probably</TD></TR></TABLE>
I'm having the same proplem bro.
where is that ignition swith?
I've gotten the main relay done 1yr ago
recently replace cap and rotor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">
Under the steering column covers.
