Sparco bottom mount for Integra doesn't fit!!!
I have the Sparco REV seat, along with the side mount, sliders and bottom end. Today, I test fitted the seat. The back 2 holes didn't fit. Does anyone have the same problem? What can I do to resolve this?
You probably purchased the Civic seat mount bracket. I have the same combo in my integra except only one of the rear pieces did not fit. I had the leg modified and then it bolted in ok but it was still too high with my racing helemt so I had my mechanic cut off about half inch on each side, reweld the mounts and bolt it back in.
You may want to look into different mounts if you don't want to cut and weld. I think Wedge makes custom mounts.
