Full Race motor from JG For sale or TRADE
Old Mar 22, 2004 | 07:54 PM
12SecHatch's Avatar
Default Full Race motor from JG For sale or TRADE
sold
Engine block prep. New GEN 3 block prep $795.00
Hot tank and clean yes included in gen 3
Step deck yes .0035 included in gen 3
Resleeve Yes Highest quality ductile iron included in gen 3
Bore cylinders 84mm included in gen 3
Power hone Yes, finished with sunnen AN300 stones included in gen 3
Deck block surface Yes, micro finish included in gen 3
Micropolish crank yes $50.00
Balance Yes, ultra balanced $150.00
Main bearings Yes, using hand lapped oe bearings $90.00
Rod bearings Yes, using hand lapped oe bearings $75.00
Thrust bearings yes $20.00
Oil pump TypeR with toda gear $300.00
Seals and gaskets yes $100.00
Oil pan cleaned
Con rods ESP turbo rod with custom age rod bolts $460.00
Pistons JE $460.00
Piston size 84mm
Comp ratio 9.0
Ring pack JE $110.00
Head studs ARP $140.00
Head gasket Cometic HP turbo $95.00
Timing belt New belt $65.00
Cam gears JG billet $150.00
Camshafts JG 296 300 cams ground on new cores $750.00
Cylinder head Full race. The very best we have
Port work Full competition port and polish $750.00
Intake valve guides Tapered $40.00
Exhaust valve guides Tapered down
Valve spring retainers Titanium 6AL4V $130.00
Valve springs JG dual $220.00
Valve job Full radius intake and 3 angle exhaust $150.00
Intake valve seats JG oversize custom seats $160.00
Intake valves Stainless steel 35mm $120.00
Exhaust valves Stainless steel 28.5mm $120.00
Valve seals New $20.00
Chambers Polished
Cleaning Hot tanked $20.00
Blue print and assemble engine, set all clearances $950.00
Total for engine $6,490.00 plus tax and shipping
after tax $7250 for motor plus shipping and core gsr long block $2000 for gsr long block
so total on this motor was spent $9250 plus shipping on 2 long blocks
i]
Modified by 12SecHatch at 8:12 AM 4/15/2004
Modified by 12SecHatch at 2:12 PM 5/6/2004
Modified by 12SecHatch at 7:40 AM 8/17/2004
Old Mar 22, 2004 | 08:05 PM
12SecHatch's Avatar
Default Re: Full Race motor from JG For sale or TRADE (12SecHatch)
other items that i can put in with the motor
again need to look at invoice to get exact info on these parts
Modified by 12SecHatch at 9:21 PM 3/22/2004
Modified by 12SecHatch at 2:50 PM 6/15/2004
Old Mar 22, 2004 | 08:20 PM
SoulSurfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SecHatch &raquo;</TD></TR><TR><TD CLASS="quote">other items that i can put in with the motor</TD></TR></TABLE>
You make it sound as if they would be free.
Old Mar 22, 2004 | 08:22 PM
12SecHatch's Avatar
Default Re: Full Race motor from JG For sale or TRADE (SoulSurfer)
my bad
there not
ALL NEW PARTS
Old Mar 22, 2004 | 08:56 PM
12SecHatch's Avatar
trade's that would be considered
cars
honda or acura's
if you have a car you feel is worth more
we have a 97 cx hatch 90k miles on,
clear title
that is being sold for 5500
Old Mar 22, 2004 | 09:14 PM
Crab-Cakes's Avatar
message sent
Old Mar 22, 2004 | 11:27 PM
dmecarboy's Avatar
Default Re: (HybrdEK)
How much for the wastegate? Also size!
Old Mar 23, 2004 | 03:40 AM
GSRswapandslow.
Guest
Posts: n/a
i'll trade you a BNIB Tial BOV for the HKS one
Old Mar 23, 2004 | 07:14 PM
12SecHatch's Avatar
Default Re: (dmecarboy)
wastegate and bov will only sale with or after the motor does
Old Mar 23, 2004 | 07:31 PM
JG90CRX-Si's Avatar
Default Re: (12SecHatch)
Please send info on engine and what your asking.
Thanks
JG
Old Mar 23, 2004 | 07:53 PM
b16_madman's Avatar
Default Re: (JG90CRX-Si)
holy freakin nuts!
soulsurfer told me bouts it...he's a good guy
Old Mar 23, 2004 | 08:51 PM
12SecHatch's Avatar
Default Re: (B16_madman)
soul surfers my bro
Old Mar 23, 2004 | 09:03 PM
Danger's Avatar
what size turbo is that ?
bump
Old Mar 23, 2004 | 09:33 PM
Crab-Cakes's Avatar
whats all the specs on the motor??
Old Apr 7, 2004 | 09:01 PM
12SecHatch's Avatar
specs can be emailed to you
Old Apr 8, 2004 | 01:15 PM
12SecHatch's Avatar
TTT
Old Apr 8, 2004 | 09:30 PM
12SecHatch's Avatar
BUMP
Old Apr 9, 2004 | 02:41 AM
12SecHatch's Avatar
Old Apr 9, 2004 | 11:37 AM
12SecHatch's Avatar
bumpy bump
Old Apr 9, 2004 | 04:45 PM
12SecHatch's Avatar
ttt
Old Apr 12, 2004 | 11:55 AM
12SecHatch's Avatar
ttt
Old Apr 12, 2004 | 02:35 PM
95turbohatch's Avatar
Trade for a 95 hatch, Sohc turbo??
Old Apr 12, 2004 | 03:51 PM
12SecHatch's Avatar
Default Re: (95turbohatch)
need a little more then that
Old Apr 13, 2004 | 03:18 PM
xtremeness101's Avatar
whats the specs on the turbo??
Old Apr 14, 2004 | 08:54 AM
12SecHatch's Avatar
ttt
