Replacing synchros/gears
Old Oct 22, 2001 | 06:15 AM
sackdz's Avatar
Default Replacing synchros/gears
Background:
I started grinding the 2-3 shift at high rpms at redline. I was just at a track event, and beat on that already worn synchro pretty bad. Now it grinds even at low rpms on the street.
I will be swapping a 4.875 FD in this winter, and will take that opporitunity to replace worn synchros as well.
Question:
1) There are 3 synchros in our tranny, correct? the 1-2 the 3-4 and the 5?
2) If I grind the 2-3 shift, it means the 3-4 synchro is bad?
3) Would 3rd gear normally need to be replaced, or just the synchro?
4) Is it advisable to replace all synchros at this time, or just the problematic ones?
Thanks for you input
Old Oct 22, 2001 | 07:26 AM
JSpecwest's Avatar
New User
Default Re: Replacing synchros/gears (sackdz)
Yeah I was wondering the same thing. Does anyone know how spendy this is going to get because my tranny is off right now so I could fix mine. Is it difficult to do?
Old Oct 22, 2001 | 08:08 AM
jeff652's Avatar
1-2, 3-4, and 5-R (Three total)
Here's the 5-R syncro:
If you grind going into third, not coming out of second, then yes that would indicate the 3-4 syncro si where the issue is.
Just the Syncro.
Depends. They run ~100-125 each. It's better to replace all (basically new trans after that) but do you want to spend the $
Old Oct 22, 2001 | 08:18 AM
stizzit's Avatar
Default Re: Replacing synchros/gears (jeff652)
Jeff - How hard is this project to undergo? I need to replace two syncros in my brothers tranny ('95 LS) which will be cheaper than buying a whole new tranny, just wana know how hard it'll be. TIA
Old Oct 22, 2001 | 08:25 AM
jeff652's Avatar
Default Re: Replacing synchros/gears (stizzit)
It's easier than doing a motor swap. Just be sure you have a Hemls and follow it closely. If you can do a timing belt change, you can do this.
Old Oct 22, 2001 | 08:31 AM
sackdz's Avatar
Thanks, you are very helpful
Old Oct 22, 2001 | 08:39 AM
jeff652's Avatar
On thing I forgot to note though is you will need a press to remove gears from the shafts . . . . .
Old Oct 22, 2001 | 08:41 AM
sackdz's Avatar
a press or a puller?
Old Oct 22, 2001 | 08:48 AM
Willard's Avatar
Both would help.
Will
Old Oct 22, 2001 | 01:58 PM
D's Avatar
D
mmm, i just got 1-2 synchro set today. not fuggin cheap.
D
ilikepho
Dec 28, 2007 08:59 PM
TASH391
Mar 10, 2006 03:31 PM
peacexisxfree
Jul 2, 2005 11:53 AM
bon3
Jun 13, 2005 10:40 AM
modulo_s
Mar 27, 2005 07:31 AM
