Quick answer needed... 3" to 2.5" DP into 2.5" exhaust....
Old Mar 22, 2004 | 06:47 PM
Derek14's Avatar
Default Quick answer needed... 3" to 2.5" DP into 2.5" exhaust....
Is it gunna be a waste of a DP to make a 3" DP go into a 2.5" exhaust? Or better saying, am I better off just doing a 2.5" DP into 2.5" exhaust on a boosted(6-12 lbs) type r motor? Bigger piping will spool my turbo faster, yada, yada... but will the bigger DP be negated once it hits the bottleneck of 2.5"? I want to keep the exhaust 2.5 inch for quietness..UNLESS there is a way to make a 3" sound as quiet... I'm torn here because I want this car to be quiet but can get a great deal on a stainless 3" DP that will rock my world.... and no, i dont wanna run an e-cutout..... post em up, thanks doods
Old Mar 22, 2004 | 07:13 PM
phatrick2332's Avatar
Your exhaust only flows as good as the smallest point. Id say your fine with a 2.5 if your exhuast is 2.5.
Old Mar 22, 2004 | 07:17 PM
Derek14's Avatar
Default Re: (phatrick2332)
Well, i should be making upwards to 350whp with my setup... so i was thinking the 3" exhaust would do me well... and help the motor breathe, help my spool times and net higher HP levels... cmon, more more more....
Old Mar 22, 2004 | 08:03 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: (Derek14)
i was wondering the same, i have 2 1/4 exhaust pipes but im gonnna stick with them because i don't have the funds to get anything bigger at this point and time, but i wanted to ask, would a 3' DP running into 2 1/4 pipe be restrictive? or will it be "ok" just wondering thanks
Old Mar 22, 2004 | 09:45 PM
Derek14's Avatar
Default Re: Quick answer needed... 3" to 2.5" DP into 2.5" exhaust.... (Derek14)
somebody knows something we wanna know....
Old Mar 23, 2004 | 09:10 AM
Derek14's Avatar
bump for an answer... cmon just a few more that are good and ill shut up, i promise
davidluko
Apr 26, 2007 10:27 AM
A.E Motoring
Mar 8, 2006 05:53 AM
Haleiwa-Brando
Sep 9, 2005 05:20 AM
AzntaggeR
Mar 12, 2005 09:49 AM
integranator
Nov 2, 2003 08:50 PM
