Which turbo for my built B20?
Old Mar 22, 2004 | 05:18 PM
TrumpTiteJoker's Avatar
Default Which turbo for my built B20?
Okay, here we go. I'm having a B20 built to handle up to 700hp. My goal is 550hp but i had it built for 700 to be on the safe side or in case i want to boost a little more. I'm wondering if you all can give me your suggestions on a few turbo's. I don't want to have to boost over 40psi but I want as minimal turbo lag as possible so I can utilize a wider powerband from the turbo. All suggestions for my setup will be appreciated.
Old Mar 22, 2004 | 05:35 PM
jmagner's Avatar
Default Re: Which turbo for my built B20? (TrumpTiteJoker)
The precision website says the SC61 is rated up to 680HP, that seems to be in your range.
Old Mar 22, 2004 | 05:37 PM
DaX's Avatar
DaX
Loved
Community Favorite
holy ****, let's hope you don't have to boost over 40 psi. what kind of engine management will you be using?
Old Mar 22, 2004 | 05:46 PM
Hondata for engine management. Also, I don't want to go with the SC-61 because from what I've read, you don't reach full boost until your about to shift. And thats on v-tec setups. <----- correct me if im wrong
Old Mar 22, 2004 | 05:50 PM
DaX's Avatar
DaX
Loved
Community Favorite
Maybe a T3/T4 with like a .60 compressor AR and a .48 turbine AR
Old Mar 22, 2004 | 06:41 PM
Oh yeah, btw, my C/R is 10.4:1. Any other suggestions?
Old Mar 24, 2004 | 05:16 PM
mal42985's Avatar
Why not go standalone? Hondata is a great tuning device but to get the best power off of less boost you need better management. I suggest getting a standalone such as AEM EMS.
40 psi will give you well over what you are looking for. Don't get ahead of yourself. Make sure you do alot of research before moving forward.
Old Mar 25, 2004 | 02:59 PM
jmagner's Avatar
Default Re: Which turbo for my built B20? (mal42985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mal42985 &raquo;</TD></TR><TR><TD CLASS="quote">Why not go standalone? Hondata is a great tuning device but to get the best power off of less boost you need better management. I suggest getting a standalone such as AEM EMS.</TD></TR></TABLE>
many will disagree with this, but lets not get into that discussion.
I have an EMS, but haven't installed it yet so I can't give my .02 on it.
From what i've read Hondata and the AEM are very comparable.
Old Mar 25, 2004 | 04:41 PM
99B16Si's Avatar
your b20 will have no problem hitting 20-25psi before 5500 on a sc61 which gives u plenty of room for a decent powerband
Old Mar 25, 2004 | 04:50 PM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrumpTiteJoker &raquo;</TD></TR><TR><TD CLASS="quote">Also, I don't want to go with the SC-61 because from what I've read, you don't reach full boost until your about to shift. And thats on v-tec setups. &lt;----- correct me if im wrong</TD></TR></TABLE>
this is not accurate. i get full boost by 4500 (10psi).
Old Mar 25, 2004 | 05:26 PM
99B16Si's Avatar
i good equal length manifold and properly sized downpipe can reduce spools times as much as 700-800rpm lower also
rEnZ94tEgGy
Nov 15, 2008 06:12 PM
urtz
Jan 20, 2007 09:02 PM
Ben Ogle
Aug 19, 2006 10:17 PM
GoCarInteg
Nov 13, 2005 12:35 AM
Ef-er
Jul 1, 2004 02:46 PM
