water pump\timing belt change...any tips?
Old Mar 22, 2004 | 01:14 PM
Project_ED8's Avatar
Default water pump\timing belt change...any tips?
ok so i think i'm going to try and tackle this water pump\timing belt change. any helpful tips or advice please? also...for the water pump is there 2 gaskets i need? i was on the kragenautoparts website and it showed a "pump to block" gasket and also a "water pump" gasket...i'm assuming these 2 gaskets are the same thing, but they just labled it different names cause the 2 gaskets were from different companies. but yeah...also for the timing belt change...do i need to replace any seals or anything? ok thanks a lot guys
Old Mar 22, 2004 | 01:37 PM
koto SM2's Avatar
Default Re: water pump\timing belt change...any tips? (Project_ED8)
The water pump has one gasket, use Hondabond or similar sealant, and unless you have a crank pulley holder tool or a really powerful wrench, you may want to have a shop break the crank pulley bolt loose for you before you begin, trust me it's on there tight!!
unhappy_idle
May 22, 2006 10:16 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
lv6l
Oct 14, 2005 11:52 AM
91tegrals
Jan 16, 2004 04:13 PM
Origin
Nov 15, 2003 09:33 PM
