Ls/Vtec into 89 Crx Si
Old Mar 22, 2004 | 12:33 PM
Cractos's Avatar
Default Ls/Vtec into 89 Crx Si
What do I need to bolt it in? I have avid mounts but do i need anything else to drop it in.
Old Mar 22, 2004 | 12:37 PM
krissi's Avatar
Default Re: Ls/Vtec into 89 Crx Si (Cractos)
WHAT YEAR IS THE MOTOR?
Old Mar 22, 2004 | 12:43 PM
cavakilla's Avatar
you will need shift linkage unless it came with your swap... block mount may be an issue depending on which one you have... do you have 90-93 teg rear mount? let us know what all you have then we can help you more... good luck!
Old Mar 22, 2004 | 02:01 PM
Cractos's Avatar
I have a shift linkage....I have a b18a with a b16 head.... I think i need the 90-93 rear mount.
Old Mar 22, 2004 | 03:02 PM
krissi's Avatar
Default Re: (Cractos)
u need a 90-93 intermediate shaft. what trans r u using?
Old Mar 23, 2004 | 03:31 PM
Cractos's Avatar
Y1 16 Cable Trans... I have the axles
awdriscol4
17
Nov 29, 2004 04:28 AM
STHPERFORMANCE
Jan 10, 2003 04:51 PM
pfcfutrell
Aug 8, 2002 07:35 PM
Mr Furball
Aug 8, 2002 10:03 AM
rocket_R
May 2, 2002 11:32 AM
