loud thunk when i let off the gas
i just bought a g3 integra that has some issues (needs tie rod ends, LBJ's, axles). well... i just replaced all that stuff and now when i let off the gas in 1st or 2nd when i'm 3000rpm or higher it goes CKKKK. on the driver side axle the outside part of it (that goes into the hub assembly) moved and twisted with ease, while the inside was hard to turn and twist. on the passenger side it was the opposite, the outside (the part that goes into the hub assembly and twists when you turn your wheel) was hard to move..
so i decided to ask the gurus :D
any ideas?
i have lifetime warranty on these autozone rmfg'd axles...
sounds like a short gear grind almost...
any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90gs »</TD></TR><TR><TD CLASS="quote">... on the driver side axle the outside part of it (that goes into the hub assembly) moved and twisted with ease, while the inside was hard to turn and twist. on the passenger side it was the opposite, the outside (the part that goes into the hub assembly and twists when you turn your wheel) was hard to move...</TD></TR></TABLE>That doesn't sound good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90gs »</TD></TR><TR><TD CLASS="quote">i have lifetime warranty on these autozone rmfg'd axles... </TD></TR></TABLE>So what are you waiting for? Sounds like you won't even have to pay for the new ones.
take the dead body out of the trunk- that should help get rid of some of the noises-
Replace the axles and then proceed from there- you'll have to just take one thing at a time to get everything taken care of
wu tang
Dec 14, 2007 05:31 AM
wu tang
11
Jan 17, 2006 11:24 PM
jondancer
May 10, 2004 04:32 PM
