Downforce over the front wheels theory *pic*
Old Mar 22, 2004 | 08:34 AM
Boostage's Avatar
Default Downforce over the front wheels theory *pic*
The VIS invader hood has a large vent across the front. now if the engine bay gets air from underneath and it rushes up into the bay towards the top, wouldnt it continue thru the vent and out towars the back creating a good amount of downforce at higher speeds? this is what the hood looks like...
Old Mar 22, 2004 | 08:52 AM
Honda Hick's Avatar
Default Re: Downforce over the front wheels theory *pic* (Boostage)
Even if it did put some downforce over the front wheels (i doub it) at real high speeds, you'd be moving fast enough where traction really wouldn't be an issue I would think.
Old Mar 22, 2004 | 09:10 AM
5STAR3's Avatar
Default Re: Downforce over the front wheels theory *pic* (Honda Hick)
just put a big GT style metal wing on the front of your car.
Old Mar 22, 2004 | 09:59 AM
Team 4's Avatar
Default Re: Downforce over the front wheels theory *pic* (envision2teg)
As much as people bitch about them, canards make a NOTICABLE difference at anything above 70 mph. Nothing will beat a properly designed airdam though.
Old Mar 22, 2004 | 10:36 AM
kpt4321's Avatar
It won't so much increase downforce, is it will reduce lift.
Most street cars have a decent amount of lift at speed; your going to need a bit of solid aero work to even start making downforce.
A hood like this will help decrease the lift a LITTLE bit, because you don't have as much turbulent hot air going under the car. However, the difference isn't enough to worry about too much on its own.
gdrum
Dec 25, 2005 03:34 PM
Rod.
Dec 14, 2004 03:09 PM
Boostage
Mar 29, 2004 11:33 AM
Boostage
Mar 26, 2004 05:06 PM
Boostage
Mar 22, 2004 10:11 AM
