Will Civic TB fit a 94+ GSR?
Old Mar 22, 2004 | 08:25 AM
Gs-RAW's Avatar
Default Will Civic TB fit a 94+ GSR?
This might be a dumb question, but I just wanna know if a 92-95 civic si, throttle body will fit on my 94+ gsr.
I need to replace the tps sensor, It will be a ton easier to just replace the whole tb, instead of trying to get the tps out (its riveted) so, just curious if anyone knows if i can just replace the whole throtle body?
Thanks!
Old Mar 22, 2004 | 09:40 AM
Gs-RAW's Avatar
Default Re: Will Civic TB fit a 94+ GSR? (Gs-RAW)
Anyone?
Old Mar 22, 2004 | 10:36 AM
AllMotorGSR94's Avatar
if its off a B16a then yes it will...
just about all b-series parts can be swap between eachother.
but why downgrade? the civic is smalled TB size than the GSR. Unless its ported
Old Mar 22, 2004 | 10:52 AM
TurboBumblBee's Avatar
double posting is not nessesarcy when you already got your answer in the civic forum
Old Mar 22, 2004 | 11:13 AM
Gs-RAW's Avatar
Default Re: Will Civic TB fit a 94+ GSR? (hybrid94Si)
I got the answer now. Sorry Canadian Si is I think ur EX (SOHC) if it were from the b16 i would just change it. But its off the SOHC civic.
Ohh well I guess i got some mcgyver work to do.
Old Mar 22, 2004 | 11:38 AM
JDM4DR.GSR's Avatar
you could take a cutting wheel and cut a slot in the rivet then take a screwdriver and unscrew the rivet
Ep1dem1c
Jul 5, 2007 04:51 PM
Gs-RAW
Mar 22, 2004 09:43 AM
tvrsir
Sep 3, 2002 07:37 PM
