Sqeeking brakes
Old Mar 22, 2004 | 07:18 AM
.M.'s Avatar
.M.
Default Sqeeking brakes
My rear brakes started squeeking pretty loud but only once in awhile when driving. The first couple stop lights it would squeek, then it would stop. Is it the pads that need replacing? how much would it cost?
Old Mar 22, 2004 | 07:34 AM
LowTEC SaiMike's Avatar
Default Re: Sqeeking brakes (BaLcH1o4sHeEzY)
they just need to be warmed up ....... are they like kragen brakes ?
Old Mar 22, 2004 | 10:05 AM
chinaski's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BomBoi &raquo;</TD></TR><TR><TD CLASS="quote">they just need to be warmed up </TD></TR></TABLE>
agreed, ive got the same problem and i know they arent worn cuz theres still about 80% of the pad left. probably just got some shitty pads
Old Mar 22, 2004 | 10:13 AM
VTECorona's Avatar
Default Re: Sqeeking brakes (GeeSeR96)
It could be the wear indicators starting to brush against your rotors. Take a look at your pads and see how much meat they have left on them. If it is still decently thick then your pads are still good.
Old Mar 22, 2004 | 11:04 AM
aeon's Avatar
not sure if this is right but i my friend bought a car awhile back, and his brakes were sqeeking really bad. we went to the dealership and they said that new brake have something like metal or something in them that makes it sqeek. it's there to make the brake pads last longer or something. my brothers rsx also sqeek and he bought his brand new.
Old Mar 23, 2004 | 08:30 AM
.M.'s Avatar
.M.
Default Re: (aeon)
does it cost extra to purchase the brake pads with lifetime warrenty?
Old Mar 23, 2004 | 08:36 AM
G
sh!t happens.
Default Re: (BaLcH1o4sHeEzY)
? there is no brake pad with a lifetime warrenty...
Old Mar 23, 2004 | 08:59 AM
.M.'s Avatar
.M.
Default Re: (G"UNIT)
autozone lifetime warrenty correct?
Old Mar 23, 2004 | 10:56 AM
PnX-R's Avatar
When in doubt check for TSB's.. And guess what, there's one out there for 3rd gen Integras about the rear brakes squeeking. It says to replace w/ OEM brake pads and shims and apply molykote or something on the shims to help the shims absorb the vibrations..
Mine never did this until my mechanic said that I can just throw the shims away because I don't need them. I guess he really doesn't know what he's talking about sometimes..
Good Luck..
Old Mar 23, 2004 | 03:12 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaLcH1o4sHeEzY &raquo;</TD></TR><TR><TD CLASS="quote">autozone lifetime warrenty correct?</TD></TR></TABLE>
What they mean by that is warranty against defects and premature deterioration. There is no brake pad that has the lifetime warranty that you're thinking of.
Old Mar 23, 2004 | 03:21 PM
J4MESK1M's Avatar
Old Mar 23, 2004 | 03:52 PM
quikrpm'z's Avatar
i just changed my rear pads today. Its very easy. Oem pads cost around $53 bucks. Diy.
Old Mar 23, 2004 | 08:28 PM
VTECorona's Avatar
Default Re: Sqeeking brakes (quikrpm'z)
Yes, switching brake pads is probably the easiest DIYer. Front pads are a tad bit easier to change than the rear.
GuCCi_GSR
Jan 30, 2008 10:25 AM
Lewie
Apr 13, 2005 05:44 PM
1hotintegra
10
Aug 7, 2002 07:01 PM
1hotintegra
Aug 6, 2002 06:09 PM
metal-x
Jul 20, 2002 05:53 PM
