Brake Line Fitting Size
Old Mar 22, 2004 | 12:52 AM
ion_four's Avatar
Default Brake Line Fitting Size
There's a hydraulic shop here in town that sells various lengths of Goodridge SS brake line for universal fitment, but I need to buy the proper adapter for the metric female fitting.
I know that the rear of my 93 Civic EX non-ABS (originally rear drums, not with discs) uses a 10x1.25mm fitting, but the front appears to be a different thread pitch! Can someone verify this?
Either I was sold something that is not 10x1.25mm, or the fronts are different.
FYI, this has turned-out to be more expensive than just buying a Goodridge kit. I'm just odd like that.
Old Mar 22, 2004 | 11:38 AM
ion_four's Avatar
Default Re: Brake Line Fitting Size (ion_four)
TTT I just need to know if the front hard lines have the same size/pitch fittings for the brake hoses as on the rear of a 93 Civic EX Coupe non-ABS rear drum...I would just take the line in and match it up, but it's my daily-driver.
Old Mar 22, 2004 | 05:21 PM
ion_four's Avatar
...Just want to know if the flare nut fittings on the ends of the hardlines are theb same size on the front and rear of an EG-era civic? Someone has to know...
bluedragon
Suspension & Brakes
Mar 30, 2017 05:11 PM
civicflow
Aug 1, 2010 05:24 AM
ZCcivic91
Apr 27, 2009 01:50 PM
ion_four
Mar 26, 2004 09:49 AM
