bogging jdm d15b
Old Mar 21, 2004 | 11:33 PM
kidd15bvtec's Avatar
Default bogging jdm d15b
ok i had just got a jdm d15b in my 95 civic hb at first it was driving ok then the next day when i step on the gas the car would bogg and then drive normal and at times it was just bogg all the time in every gear i got 4-1 dc headers and a short ram intake just to start off then too my car idles too too low when im at a stop light like it wants to turn off but then at times it would stop and fell fine just gottin a new dizzy , and battery was wondering what can be causeing it too bogg thanx
Old Mar 21, 2004 | 11:44 PM
chameleon's Avatar
Default Re: bogging jdm d15b (kidd15bvtec)
wow periods would be a plus. and sentences...
um do a compression test first of all, then usual maintenance, like plugs and wires since you just did new distributor, and i guess check your timing.
Old Mar 22, 2004 | 10:14 AM
Default Re: bogging jdm d15b (jerseykid609)
oh rite koo thanx for the info.
Old Mar 22, 2004 | 07:00 PM
ok i got another question can vtec engage without the vtec oil pressure sensor? cuz on my motor it doesnt have the vtec oil pressure sensor insted it has a screw.
Old Mar 23, 2004 | 01:53 PM
n e one?
Old Mar 23, 2004 | 05:45 PM
iwhichisme's Avatar
Sounds like you may have an issue with your timing, is it set correctly?
Old Mar 23, 2004 | 09:25 PM
Default Re: bogging jdm d15b (iwhichisme)
yea i fixed that problem it was the dizzy and that the idle was way too high and that a vaccum hose was loose but now i wanna hook up my vtec but my motor did not come with the oil pressure sensor ( its that green plug) i was wondering if i can wire vtec without it?
InTheLBC20
Jan 4, 2009 09:04 PM
andrewmt19
13
Aug 7, 2007 06:56 AM
h22kevin
Mar 7, 2006 11:56 AM
BumpinVTEC
May 1, 2005 08:51 AM
DIYMIKE
May 30, 2004 05:29 PM
