Help: J&S Safeguard with Dual Monitor
To the folks who have installed a J&S Safeguard with Dual monitor...
I can't seem to get my air/fuel meter working on my '95 GSR. My J&S is working flawlessly, but I don't know how to wire in the air/fuel meter for some damn reason. The install is different than my Autometer since there is no power wire, but there are 2 signal wires. Where do these wires go (what wires to tap/splice)? The black is ground, but I am clusless on the other two wires. Can anyone here give me specific instruction on how to make the air/fuel meter work?
Thanks guys!
Thanks guys!
Tony...I grounded the bare wire near the ECU...I connected the other wires to the O2+ and O2- for the primary O2 sensor at the ECU wiring harness.
Austin
Austin
Thanks Austin for the help,
However, I spliced the O2 (big white wire) and had the +/- terminal of dual monitor wire connected at the ECU, but I get all these weird readings. I don't know what's wrong since I installed at exact same way as you did Austin. The '95 GSR has the 2 wire O2 sensor, but the J&S instructions only mentioned where to connect the wires for 4 wire sensors and one wire sensors.
Will it work if I tapped the two 02 sensor wires near the O2 sensor?
I dunno why I am stuck at the damn air/fuel meter! The J&S install was a piece of cake, but why the f*ck is it so hard to make the A/F work?
dude.. ignore what the instructions for the 4 wires say. all u need is connect the + wire to the white wire at the ecu. then ground the - and black wire at the ecu or chassy. if u have the +/- wire both connected to the white wire at the ecu.. then u got it wrong. hope that help u.
[Modified by fiyaboi, 10:39 AM 10/24/2001]
