My injector plugs are cut...can i re-wire them?
Old Mar 21, 2004 | 08:57 PM
Ryan C's Avatar
Default My injector plugs are cut...can i re-wire them?
the harness that came off the GSR that i am putting in my EG has the injectors cut off.
Naturally ther are 8 wires... (2 per injector)
a yellow, blue, brown & red.
and 4 yel/blk wires.
i know they are 12v power for the injectors and i assume it doesnt matter whick one goes where, but can anyone verify this?
Old Mar 21, 2004 | 09:28 PM
igor's Avatar
Default Re: My injector plugs are cut...can i re-wire them? (Ryan C)
At risk of sounding like an idiot...
The Black/Yellow sound like a ground/common, and the four coloured wires sound like individual injector wires.
It could be critical that a certain injector has a certain colour wire going to it, but then again it might not.
EDIT:: I think this is what you will be looking for dude, the integra GSR wiring diagram.
http://hybrid2.honda-perf.org/...1.gif
Bottom left corner has the four injectors marked out.
Old Mar 21, 2004 | 10:08 PM
Syner-G-Racing LLC's Avatar
Default Re: My injector plugs are cut...can i re-wire them? (igor)
you have a sequentialy injected system...it makes all the difference on which wire you hook to your injectors. there should be a common wire and the signal wire. just make sure you dont cross up your signal wires and if their sheilded make sure you ground the drain wire.
Old Mar 21, 2004 | 10:09 PM
Ryan C's Avatar
yup, in that picture it looks like all the yel/blk's end up in the same place.
problem solved
Old Mar 21, 2004 | 10:10 PM
Ryan C's Avatar
Default Re: My injector plugs are cut...can i re-wire them? (Syner-G-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">you have a sequentialy injected system...it makes all the difference on which wire you hook to your injectors. there should be a feed wire, common wire and the signal wire. just make sure you dont cross up your signal wires and if their sheilded make sure you ground the drain wire. </TD></TR></TABLE>
there is only 2 wires per injector, not 3
Old Mar 21, 2004 | 10:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">
drain wire, wtf?</TD></TR></TABLE>
on a sheilded cable you twist the end of the sheild and ground it...this wire is called a drain wire because, that is its purpose, it drains any induced voltage to ground and keeps the proper impedance.
Old Mar 21, 2004 | 10:15 PM
there is only 2 wires per injector, not 3</TD></TR></TABLE>
yeah i caught that, If its sheilded, then you will have three wires, the feed wire is the feed to the main "drain" wire for bleed off, etc.
Old Mar 21, 2004 | 10:37 PM
Ryan C's Avatar
thanks guys
HypL
Feb 1, 2012 04:35 PM
HypL
Oct 23, 2011 07:39 PM
RTW DC2R
Jul 17, 2005 12:01 PM
Mr. Vapor
May 7, 2005 01:03 AM
schwett
Dec 30, 2003 01:38 PM
