Loose door panel? Also brake noise.
My passenger front door panel is loose, I don't know where the problem lies, it is below the latch. The outside molding from front door to rear door is off like 1/4" inch. every now and then my interior door light will come on. How do I fix? Also is there a lube on the market to fix squeky brake pads? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordCD5 »</TD></TR><TR><TD CLASS="quote"> Also is there a lube on the market to fix squeky brake pads? Thanks.</TD></TR></TABLE>
huh? have you changed them recently?
a clip has probably come undone inside the door panel, try smacking it back into place accross several areas of the door, or you can do it the right way and remove the door panel and put it back on.
suhteevin
Jan 6, 2009 09:04 PM
HATCHingMN
18
Nov 23, 2003 12:59 AM
FR-MOB: ThE bEe GuY
Jul 14, 2003 09:11 AM
