>>>>>Willem burner - is a 13.8v power supply Ok to use?<<<<<
Old Mar 21, 2004 | 08:26 PM
Bailhatch's Avatar
Default >>>>>Willem burner - is a 13.8v power supply Ok to use?<<<<<
I have read that the Willem burner is run off 12v power but I have a bench top power supply that puts out 13.8v. Will this work fine? just don't want to toast my buddies new burner.
Old Mar 21, 2004 | 08:49 PM
omahaturbocivic's Avatar
Default Re: >>>>>Willem burner - is a 13.8v power supply Ok to use?<<<<< (Bail
I am pretty sure the willem unit can take use anywhere from 12-24volt supply. I believe a few certain chips that we would never use actually require 24 to write but most only require 12. The average 12v supply puts out way more than 12 at low load anyways.
raverx3m
Engine Management and Tuning
15
Apr 23, 2014 12:23 AM
jrp355
Welding / Fabrication
Jan 2, 2013 08:30 AM
civicvtec44
May 16, 2009 09:58 PM
94B18B1Teg
May 27, 2004 11:47 AM
