a couple more head gasket questions
Old Mar 21, 2004 | 07:51 PM
ludelvr's Avatar
Default a couple more head gasket questions
Okay, I managed to successfully place the head gasket back on but I'm a bit concerned. After reconnecting all the lines, hoses and harnesses, I noticed that there's a bit of a leak coming out by the number 4 cylinder under the upper rad hose. It looks like oil but it's not coming out quickly, just looks like it stays moist.
I did notice that when placing the head back on, there was a little port under the head where when I tipped the head to the dizzy side, oil came pouring out. I tried to drain this out as best I could and then placed it back on the block. Anyway, I was wondering if anyone else had this oil in the same spot as me.
This is my firsit head gasket change and I'm sure that it didn't go 100% so if any of you can help me that would be awsome!
Old Mar 22, 2004 | 09:11 PM
ludelvr's Avatar
Default Re: a couple more head gasket questions (ludelvr)
ttt
Old Mar 22, 2004 | 11:03 PM
anothersickhatch's Avatar
i have that same thing but its on the distributor side of the head...i think that is cylinder one though.
Old Mar 23, 2004 | 08:02 AM
ludelvr's Avatar
Default Re: a couple more head gasket questions (EGB16hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGB16hatchie &raquo;</TD></TR><TR><TD CLASS="quote">i have that same thing but its on the distributor side of the head...i think that is cylinder one though.</TD></TR></TABLE>
so is your car running like that? if so, are you boosted and what problems are you experiencing?
Old Mar 23, 2004 | 09:04 AM
nope, no boost, no problems.l other than my motor tends to get a bit dirty over time
Old Mar 23, 2004 | 10:00 AM
b16 matt's Avatar
When i changed my head gasket i noticed some oil in the sam spot you are explaining. Turned out to be my valve cover gasket. You should change that too.
civicvtec16
Oct 29, 2006 10:45 AM
SlammedBlackGSR
Oct 26, 2006 06:56 PM
R6Elmo
Nov 13, 2003 04:47 PM
InfamousRS
Jun 2, 2002 08:21 AM
