how da hell do you take out the last bolt on the rear mount?
Old Mar 21, 2004 | 07:47 PM
crx_ef8's Avatar
Default how da hell do you take out the last bolt on the rear mount?
what kind of tool do i need? their is no space to stick in it, i cant even stick in my two fingers. please help! searched didnt find much.
Old Mar 21, 2004 | 09:35 PM
HandCommand's Avatar
Default Re: how da hell do you take out the last bolt on the rear mount? (crx_ef8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_ef8 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of tool do i need? their is no space to stick in it, i cant even stick in my two fingers. please help! searched didnt find much.</TD></TR></TABLE>
Hehehe, I remember thinking this years ago when I did my first Bseries EF swap.
Here is what I do,
remove the 10mm bolt that anchors that tab that holds the heater valve. That will give you some clearance to use a LONG extention.
Put a 14mm socket (short, not deep )on the rear bolt first. Then put on a swivel joint. ( You can do this before you put the socket on the bolt to)
Then using a long extension and ratchet, remove as necessary. When you get it semi-loose, you can PIVOT the rear mount either way once you have removed the other two bolts.
Hope that helps.
Old Mar 21, 2004 | 10:32 PM
DC 2's Avatar
A swivel joint would work , but im sure you know its a tight fit. I used a box wrench. You can reach that back bolt if you stick the wrench through the mount, Under the rubber , but above the x-member/or bottom of the mount. hold it str8 as possbile while you twist the mount towards drivers side loosing the bolt. After repeating process over and over it came out fairly easy.
Old Mar 21, 2004 | 10:37 PM
Rywire's Avatar
Default Re: how da hell do you take out the last bolt on the rear mount? (EH3B18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH3B18B &raquo;</TD></TR><TR><TD CLASS="quote"> You can reach that back bolt if you stick the wrench through the mount, Under the rubber , but above the x-member/or bottom of the mount. </TD></TR></TABLE>
Thats the key. Ryan
Old Mar 21, 2004 | 11:54 PM
E-lude78's Avatar
I dropped the rear crossmember by loosening the 4 bolts that hold it in place. That gave me enough clearance to stick a wrench onto that bolt.
tree fingers
Jul 27, 2008 08:13 PM
MidShipCivic
Sep 26, 2007 04:28 PM
b16a2EBP
Mar 23, 2006 08:40 AM
Ronin150
Nov 17, 2004 09:21 AM
ragejed
Jul 10, 2002 04:30 PM
